309-116_ALT_0
309-116_ALT_1
Advent ADV-W801 Indoor/Outdoor Wireless Speaker
Brand:|Part # 309-116
The ADV-W801 gives you the freedom to have your music anywhere you want. A 900 MHz transmitter sends a strong signal up to 150ft. away with the ability to transmit through walls, floors and ceilings.
  • Wireless, 20-watt indoor/outdoor speaker
  • Blends easily into most gardens
  • Splash-proof housing resists water damage
  • 5-inch woofer and 1-inch dome tweeter
  • 900 MHz wireless transmitter broadcasts up to 150 feet
  • Independent volume control and frequency adjustment
  • Runs on AC adapter (included) or 8 D-cell batteries
This item has been discontinued. For possible replacements or substitutions, please check the drop-down box below for a list of related items to view more products in this category. The ADV-W801 gives you the freedom to have your music anywhere you want. A 900 MHz transmitter sends a strong signal up to 150ft. away with the ability to transmit through walls, floors and ceilings. The unique design and green color blend seamlessly in the garden allowing you to hide the weather-resistant speaker from view while still hearing it loud and clear. The 20 watt speaker is a two-way acoustic suspension design with a 5” woofer and 1” dome tweeter. The speaker offers the ability to fine tune the frequency to remove possible interference that the speaker might receive. A L/R/mono switch allows the speaker to be used as either a single speaker in a stereo set or a mono speaker. Eight D-cell batteries power the W801 for true “wire-less” use or the supplied AC adapter can power it. Specifications: Transmitter: *Transmission range: up to 150 feet *Adjustable transmission frequency: 912.55 to 914.75 MHz. *Audio input: 3.5mm stereo mini plug (1/4” headphone adapter and “Y” cable included) *Dimensions: 4-5/8" W x 4-9/16" H x 3-7/16" D. Speaker: *Frequency range: 50 Hz - 15,000 Hz *S/N ratio: 60 dB *Dimensions: 10" H x 7.4" dia.
  • BrandAdvent
  • Part Number309-116
  • UPC079000326014
  • Product CategoryWireless & Bluetooth Speakers
  • Weight11 lbs.
