360-300_ALT_0
360-300_ALT_1
360-300_ALT_2
360-300_ALT_3
360-300_ALT_4
360-300_ALT_5
360-300_ALT_6
Adjustable Drywall and Ceiling Tile Hole Cutter 1.5" to 11"
The cutting tool is adjustable from 1/2" to 11", allowing you to easily and quickly cut round speaker holes in drywall and ceiling tiles without the mess.
  • Cuts circles up to 11-3/4" diameter
  • Carbide tipped blades for longevity of life
  • Two blades counter balance the cutter for low vibration
  • Dust shroud keeps debris from obscuring your work area
  • Includes extra set of blades
360-300
Weight: 7.75 lbs.
IN STOCK
List Price$99.99
You Save34%
$65.60
Part # 360-300
If you install speakers or can lights this circle hole cutter is a must have! The cutting tool is adjustable from 1/2" to 11", allowing you to tackle the biggest jobs without making a mess. Carbide tipped blades and high-speed steel bits will go through drywall and ceiling tiles with ease. A ball-bearing collar in the dust shroud allows the cutting tool to spin effortlessly. The complete kit includes the circle cutting tool, one set of carbide tipped and one set of high-speed steel cutting blades, one carbide tipped and one high speed steel arbor bit, dust shroud, five wood and five masonry drill bits, tape measure and pencil all organized in a heavy duty case. Maximum cut depth is 1-1/4", overall plastic shield diameter is 14-1/4". Not recommended for use on concrete or hardwoods.
  • BrandParts Express
  • Part Number360-300
  • UPC844632085949
  • Product CategorySaws / Hole Saws
    (8 Reviews)
  • Weight7.75 lbs.
View similar products to the Adjustable Drywall and Ceiling Tile Hole Cutter 1.5" to 11"
in the Saws, Hole Saws & Ceiling Hole Cutters product category.
Adjustable Drywall and Ceiling Tile Hole Cutter 1.5" to 11" is rated 3.875 out of 5 by 8.
Rated 5 out of 5 by from Great time and money saverI used this to cut in about 30 commercial audio speakers, it saved me time on the install and the clean up. It is well worth the investment. I wish I had this years ago.
Date published: 2014-02-22
Rated 4 out of 5 by from Works pretty wellCut in 6 - 11" holes for ceiling speakers quickly with no issues.Need a drill with a fair amount of torque, but all in all worked very well and seems to be well made.Shipping was AMAZING, ordered Tuesday at around 10 pm and received it Thursday morning
Date published: 2013-05-12
Rated 5 out of 5 by from Huge time saverI've used this to cut holes for a number of 6" recessed lights, and a couple 8" ceiling speakers so far, and am quite impressed.Before purchasing this, I had installed a few ceiling speakers at a friend's house using a hand drywall saw. While the holes I cut by hand were ok, I ended up with drywall dust all over me and the floor, and a very tired + sore arm.Once you set the blade width on this cutter, it only takes a few seconds to make a perfect, clean-cut circle, with no mess!Added bonus is that since the dust shield is pressed against the ceiling, once you cut all the way through, your drill bits are limited to how far into the ceiling they go. (so there is less risk of hitting anything inside the ceiling cavity.)
Date published: 2013-03-22
Rated 5 out of 5 by from This tool is awesome!I agree with velmeran42, this tool is awesome! I cut 13 holes (for recessed lighting) in my kitchen drywall ceiling in less than ½ hour. After a couple minutes of getting used to it, it’s easy to use, fast, and effective!I would NOT suggest using it for wood (with a powerful drill it might rip your arm off) but for drywall and/or ceiling tiles, it is by far the easiest and cleanest way to cut it!
Date published: 2013-03-17
Rated 5 out of 5 by from Understand what you're buyingI can't even begin to understand the 2-3 star ratings people have dished out on this product.... It is a very well built fly adjustable fly cutter and a great value for the money. It comes with 2 sets of cutters, one with carbide tip and one that is just sharpened steel. I have used it in both drywall and through plywood / pressed particle board when I couldn't use my router and Jasper Jig (cutting holes in vintage repairman box w/ riveted hardware in the way).Things to note:* It is intended primarily to cut through drywall / ceiling tiles, not through MDF speaker baffles (although, with a little patience and a high torque drill it can)* It's adjustable; that means YOU are responsible for making sure everything is where it needs to be and tightening down the set screws, they don't magically stay where you need them* The plastic bowl guide is awesome. The shaft and bearing combo keep the cutter perfectly aligned to the cutting surface and catch the debris, really nice setupI would whole heartedly recommend this product to anybody who needs it and understands its limitations and intended usage. If you are only planning on putting holes in MDF, get a router and Jasper Jig, or a Roto-zip, you'll be way better off.
Date published: 2011-04-28
Rated 3 out of 5 by from THIS IS FOR DRYWALLTo put the other review in perspective.....I haven't used this brand specifically, but a similar tool from a different manufacturer. The product description says most building materials...not sure why....the title "Adjustable Drywall and Ceiling Tile Hole Cutter" says enough. Drywall and ceiling tiles is about all you want to try to use this tool on. For that purpose, cutting holes for in-ceiling speakers or recessed light cans...it works great. I haven't used this brand, but it looks almost exactly like the one I have used from a different manufacturer....and this one is half the price. When I need to replace mine, I will definitely try this one.
Date published: 2011-02-02
  • 2015-04-01T07:19CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_360-300, PRD, sort_mostRecent
Will it cut a plaster ceiling?
Asked by: Thenative
It probably could as long as you went slowly. I would not recommend trying to cut through lath with it.
Date published: 2014-12-11
wijj ti cut thru plexiglass?
Asked by: chris2299
I would not recommend this for plexiglass.
Date published: 2014-10-27
What is the maximum cutting depth of this tool? My ceilings have double drywall. I believe I will need to go through 1.25".
Asked by: Greg S
The maximum depth the blades will reach is 1-1/8".
Date published: 2014-09-03
Recutting a hole?
Will this work when there is no material in the center of the hole area? For example a drywall ceiling already has holes. I need a larger hole. If the plastic tub is held tight to the ceiling will I be able to cut the larger hole?
Asked by: PeteW
This would not be ideal, the center is what is used to hold the cutter from thrashing around regardless how tight the tub is held. I would not recommend using it this way.
Date published: 2013-09-03
Instructions?
Just received the Adjustable Drywall and Ceiling Tile Hole Cutter and was disappointed that there was no instructions in the box. Does this come with operating manual and mine was missing? Or am I on my own to figure out how to assemble and use the cutter?Please advise.
Asked by: Chris 1951
There is a youtube video at the top of the page that goes over how to use the product.This is a paraphrase of the video:Remove cutter and set your measurementsYou will notice one side is metric the other standardLoosen each blade with the supplied allen wrench to your desired measurement.Then tighten down.Remove the butterfly nut and spring. Then thread the cutter through the tub.Place the spring on the back side of the tub and tighten the butterfly nut.Place the cutter into your drill like any other drill bit. Mark the center ofwhere you would like your hole on drywall or ceiling tile with the includedtape measure and pencil.Now simply drill and the tub should catch your excess debris.Best of luck
Answered by: JDoyner
Date published: 2015-02-22
Would this work on cutting circles in baltic birch plywood?
Asked by: allen
it is designed for cutting ceiling tile, not wood. it is a knife, not a saw...hope this helps. m
Answered by: marksteven
Date published: 2014-06-24
  • 2015-04-01T06:50CST
  • co_hasquestionsanswers, tq_6
  • loc_en_US, sid_360-300, PRD, sort_recentQuestionsFirst
Customer projects that include: Adjustable Drywall and Ceiling Tile Hole Cutter 1.5" to 11"
