ADJ Mister Kool Low-Lying Fog Machine
Brand:|Model: Mister Kool|Part # 244-4150
The American DJ Mister Kool creates billows of fog that lay low to the ground for visual effects. The use of ice cubes and standard fog juice makes this unit cost effective to run.
Ships in 7-10 Business Days
Awaiting Updated Due Date
List Price$199.95
You Save25%
Part # 244-4150
  • Stays low to the ground, similar to the "dry ice effect"
  • Uses standard ice cubes and fog juice
  • Includes timer remote with on/off switch
  • Water drainage valve allows easy clean-up
Creating effects for Halloween and theatrical events is easy for the Mister Kool by American DJ. This unit has a 400 watt element, holds 4 pounds of ice, and half a liter of standard fog juice for optimal use. The attached valve and included drainage bag make clean up a snap. This fixture also includes a wired remote with timer and on/off switch, and removable fog fluid container.
Specifications: • Output: 2500 cu.ft/min. • Fluid consumption rate: 16~11 min. / liter (100% output); 14 min. / liter average • Dimensions: 19.25" x 12.5" x 10.25" (490 x 315 x 260 mm) • Weight: 17.5 lbs. (8 kg).
  • BrandADJ
  • ModelMister Kool
  • Part Number244-4150
  • UPC819730015761
  • Product CategoryFoggers, Hazers & Bubble Machines
  • Weight20 lbs.
View similar products to the ADJ Mister Kool Low-Lying Fog Machine
in the Foggers, Hazers & Bubble Machines product category.
