ADJ Flat Par QA5X Slim Par Wash Light 5x5W RGBA LEDs
Brand:|Model: Flat Par QA5X|Part # 244-4030
The American DJ Flat Par QA5X features five 5-watt RGBA LEDs with smooth color mixing and a true amber LED to get those hard to achieve orange and amber hues. The unit's low profile, side-mounted power & DMX in/outs, and dual hanging brackets make it ideal for mobile entertainers.
  • Ultra bright slim fixture
  • Linkable via 3-pin XLR/DMX cables
  • 8 DMX channel modes
  • 6 operational modes
Featuring 8 different DMX channel modes, sound activation, or Master/Slave modes, the American DJ Flat Par QA5X is a great asset for entertainers everywhere.  This unit can be used as a permanent fixture or easily moved from gig to gig. The light may also be inserted into a truss or used sitting on the ground to achieve an uplighting effect. Also great for performance stages where traditional par cans emit a lot of heat onto performers.
Specifications: • Wireless infrared remote control up to 15 ft./4.5 m (Model: ADJ LED RC2 - sold separately) • 6 Operational modes: Manual Color Mode; Color Change Mode; Color Fade Mode; Auto (Program Run) Mode; Sound Active Mode and DMX-512 Mode • 44 built-in color macros • LED pulse & strobe effect • Flicker free • Electronic dimming: 0 - 100% • Beam angle: 25° • IEC AC IN/OUT outlets on rear to daisy chain power (up to 18 units) • No duty cycle • Long life LEDs (50,000 hours) • Power draw: 34W max • Multi-voltage operation: AC 100-240V, 50/60Hz • Dimensions: 10.75" x 9" x 4.5" (272 x 230 x 115 mm) • Weight: 6 lbs. (2.5 kg) • ETL approved.
  • Light TypeFlat/Slim PAR Style
  • DMX-ControllableYes
  • BrandADJ
  • ModelFlat Par QA5X
  • Part Number244-4030
  • UPC640282002912
  • Product CategoryWash Lights / Stage Lighting
  • Weight7.5 lbs.
View similar products to the ADJ Flat Par QA5X Slim Par Wash Light 5x5W RGBA LEDs
in the Wash Lights / Stage Lighting product category.
