ADJ Flat Par CWWW18 Slim Par Can 18x3W White LEDs
Brand:|Model: Flat Par CWWW18|Part # 244-4024
The Flat Par CWWW18 by American DJ is a low profile par can with 18 x 3-watt white LEDs (9 "CW" cool white & 9 "WW" warm white). The versatility of being used on the ground, in a truss or hung makes it ideal for staging, permanent installations, and mobile entertainers.
  • Ultra bright slim par with 18 x 3-watt white LEDs
  • Great for performance stages
  • Low profile housing design
  • Dual bracket system allows fixture to be hung or placed on any flat surface
The American DJ Flat Par CWWW18's low profile design and dual hanging brackets along with side placement of the power and DMX connections makes it so the unit can be set flat on the ground, inside a truss for uplighting, or hung. This light has 3 DMX channels and 6 operational modes (DMX-512; color dimmer; white presets; color fade; sound active; and auto run). Smooth color mixing, strobe effect, and electronic dimming of 0-100% are additional features of this par can light.
Specifications: • IEC AC IN/OUT outlets on rear to daisy chain power • Safety hook on rear panel • Includes gel frame for optional diffusion filters • Long life LEDs (50,000 hrs.) • Power draw: 60W max • Color temperature: 3000°K – 6000°K • Multi-voltage operation: AC 90~240V 50/60 Hz • ETL listed • Dimensions: 13" x 11" x 4.25" (328 x 280 x 105 mm) • Weight: 8 lbs. (3.2 kg).
  • Light TypeFlat/Slim PAR Style
  • DMX-ControllableYes
  • BrandADJ
  • ModelFlat Par CWWW18
  • Part Number244-4024
  • UPC640282002417
  • Product CategoryWash Lights / Stage Lighting
  • Weight9 lbs.
View similar products to the ADJ Flat Par CWWW18 Slim Par Can 18x3W White LEDs
in the Wash Lights / Stage Lighting product category.
