320-924_ALT_0
320-924_ALT_1
Adafruit 1148 Half-Size Perma-Proto Raspberry Pi Breadboard
Brand:|Model: 1148|Part # 320-924
The Half-size Perma-Proto breadboard PCB kit works as a breadboard and a PCB. Prototyping for your Raspberry Pi is made easy with 1.2 mm through holes for those extra-large components. Traces can easily be cut when necessary and the gold plated finish won't tarnish.
Part # 320-924
  • All 26 pin breakouts are labeled
  • 5-hole pad design that matches a classic breadboard
  • All holes are thru-plated for strength
  • Gold plated so it won't oxidize
The Half-sized Perma-Proto has all the break out labeling that the Cobbler has, but with a built in breadboard. Once your prototypes are finalized, you can make your project permanent, right on the same board.
Just connect a 26-pin ribbon cable (GPIO cable) from your Raspberry Pi to the Perma-Proto and you can start laying out your components right away. The pin layouts printed right on the board make it easy to experiment.
Comes with one PCB and one box header, you'll need to do a little light soldering to attach the box header to the PCB but its fast and easy to do.
  • BrandAdafruit
  • Model1148
  • Part Number320-924
  • UPC848864016726
  • Product CategoryBreadboarding
  • Weight0.0025 lbs.
View similar products to the Adafruit 1148 Half-Size Perma-Proto Raspberry Pi Breadboard
in the Breadboarding product category.
