Abletec Switch Mode Power Supply +53V at 1.4A, -53V at 1.4A, +7.5V at 1.6A, +5.6V 1A
Brand:|Model: ALP0400-5301-D|Part # 129-147
This Abletec switching power supply was originally manufactured for high fidelity Class D amplifiers. Thanks to a Parts Express buyout, it can be the foundation of your next electronic project! Hurry, as quantities are limited!
Part # 129-147
  • High peak power, up to 900W
  • Complies with FCC, UL, CSA, and CE requirements
  • 85% efficiency and 1W standby power consumption
  • Protection and auto recovery circuitry
Designed for absolute, no-compromise performance, this power supply from industry-leaders Abletec has very low ripple and, under grueling EIA/CEA-490-A and FTC testing, is capable of delivering a 445 watt continuous output. Instantaneous output of 900 watts is possible. Input is a truly universal 90-264 VAC, 45-63 Hz, making this Abletec power supply useable worldwide.
When this supply was engineered, safety and compliance were put first, earning FCC, UL, CSA, and CE certification. Short circuit protection is provided through a primary limiter on the auxiliary outputs and fuses on the high voltage outputs. In an over-temperature event, the power supply will shut down and recover automatically when normal operating temperature resumes. Cooling is accomplished by an attached heatsink, but an external heatsink may be used in high-demand applications. An external high temperature indicator may be used with this power supply, as well. Dimensions: 3.38" W x 8.88" L x 1.38" H.
Output (VDC)
Output (Continuous) Output (Peak, 5 minutes) Output (Peak, 10 milliseconds) Ripple (mVp-p)
+54 V ± 3% 1.38A4.13 A16.50 A
<100 mV
-54 V ± 3%1.38AOR 4.13 AOR 16.50 A
<100 mV
7.5 V ± 3%1.60A
 <50 mV
5.6 V ± 3%1.00A
 <50 mV
Note:
This open frame power supply features exposed high voltages and is recommended for experienced technicians and engineers.
  • BrandFactory Buyouts
  • ModelALP0400-5301-D
  • Part Number129-147
  • UPC848864005317
  • Product CategoryPower Supplies
    (3 Reviews)
  • Weight2.15 lbs.
View similar products to the Abletec Switch Mode Power Supply +53V at 1.4A, -53V at 1.4A, +7.5V at 1.6A, +5.6V 1A
in the Power Supplies product category.
