Clearance Item
180-935_ALT_0
180-935_ALT_1
180-935_ALT_2
180-935_ALT_4
A/V Selector with Remote and Digital Optical 3-In 1-Out
If you have more A/V sources than your TV or receiver can handle then this 3 in 1 out audio/video switcher is the perfect solution.
180-935
Weight: 2.6 lbs.
IN STOCK
List Price$99.95
You Save43%
$56.55
Buy 4-up$53.90
Part # 180-935
DVD players, VCRs, DBS receivers, video game systems… If you have more A/V sources than your TV or receiver can handle then this 3 in 1 out audio/video switcher is the perfect solution. Route all video sources to your TV through a single cable! All three inputs allow the user to choose either composite video or S-video for the video input. The audio also has two choices for inputs either stereo line level or digital optical audio. The output has all of the same connections making it versatile enough to connect to any TV or receiver. Inputs can be selected manually from push buttons on the front or by the supplied remote control. LED's on the front have a green light for easy indication of input selection and power. A great problem solver for expanding audio and video systems! AC adaptor included.
Specifications: • Dimensions: 1-3/4" H x 9-3/8" W x 4-1/8" D.
  • Audio Input/OutputDigital Optical,L/R Analog
  • Video Input/OutputComposite,S-Video
  • BrandParts Express
  • Part Number180-935
  • UPC844632026386
  • Product CategoryA/V Source Switchers
    (13 Reviews)
  • Weight2.6 lbs.
View similar products to the A/V Selector with Remote and Digital Optical 3-In 1-Out
in the A/V Source Switchers product category.
A/V Selector with Remote and Digital Optical 3-In 1-Out is rated 4.1538 out of 5 by 13.
Rated 5 out of 5 by from Just the TicketOur new TV did not have the multitude of input options that its predecessor did. For less than $60.00, problem solved. Does what it says it will very well.Thanks!
Date published: 2012-03-24
Rated 4 out of 5 by from Simple Solution and High ValueThe switcher worked perfectly however one unexpected quirk was that the remote control did not operate the unit for the first few minutes after pulling the tab out of the battery compartment. After that it worked perfectly. Frankly, for around $50 this produced function and performance I couldn't have hoped for several years ago. The reason for the less than perfect review was that the video produced the anticipated quality of picture, which was good but not like a passthru. Otherwise I couldn't ask for more.
Date published: 2009-11-23
Rated 4 out of 5 by from Works like it should.There is nothing special about this A/V selector except that it works just like it should. I would recommennd it to anyone who is trying to extend the life of a receiver that just doesn't have enough inputs.
Date published: 2009-07-28
Rated 4 out of 5 by from Good A/V switchDoes exactly what it should. My customer was very happy with the remote and ease of use.
Date published: 2009-02-04
Rated 2 out of 5 by from Less than satisfied, seems well-built, BUTThe analog side has limited bandwidth and clips the signal (i.e. distortion) but I didn t buy this for the analog switching. The unit has optical switching with 3-in and 1-out. This seems to work just fine no signal loss. The remote is slick!
Date published: 2009-01-27
Rated 5 out of 5 by from Works perfectWas an easy set up and works as intended. Lots of features for different hook ups. The included remote has a good range and the price is very good.
Date published: 2008-10-08
Can I buy the remote controller only since mine doesn't work at all. I am pretty sure my controller is bad. How much will it be? TKS
Asked by: herman0606
Unfortunately we do not offer the remotes for these separately. If your controller has gone bad and you have tried replacing the battery, i would recommend calling our Tech support as long as the unit is still within warranty.
Date published: 2014-01-03
what are the dimensions
Asked by: flyski
Dimensions are: 1-3/4" H x 9-3/8" W x 4-1/8" D. We have added the dimensions to the description. Sorry for the oversight.
Answered by: PE Tom
Date published: 2012-04-02
Customer projects that include: A/V Selector with Remote and Digital Optical 3-In 1-Out
