140-982_ALT_0
9V Battery Holder Metal Clip
Useful for replacing worn battery holders in portable radios and other electronics. Perfect for the electronic hobbyist and kit builder.
140-982
Weight: 0.0132 lbs.
IN STOCK
$3.98
Buy 10-up$3.49
Part # 140-982
Useful for replacing worn battery holders in portable radios and other electronics. Perfect for the electronic hobbyist and kit builder. Solder tab connections.
  • BrandParts Express
  • Part Number140-982
  • UPC844632027697
  • Product CategoryBattery Holders
    (4 Reviews)
  • Weight0.0132 lbs.
View similar products to the 9V Battery Holder Metal Clip
in the Battery Holders product category.
9V Battery Holder Metal Clip is rated 4.75 out of 5 by 4.
Rated 5 out of 5 by from RefurbishedIf you are looking to replace a 9 volt battery holder in your vintage metal detector this is the product for you. The detector I have was manufactured in the early sixties and I was amazed that this battery holder was an exact replacement. All I had to do was to remove the pop rivets on the old one, put the new one in place and pop rivet it in. After attaching the power wires to the holder my detector is now back in service. Great product and I highly recommend it for the electronic hobbyist.
Date published: 2013-07-21
Rated 5 out of 5 by from Totally top qualityI needed to get the strongest and most reliable 9v battery holder and after quite a bit of searching, have found this, which is totally top quality. It's actually very easy to get the battery in and real easy to get it out - just pull the bottom of the battery up and it snaps out of the contacts without bending them, etc.
Date published: 2008-12-31
Rated 5 out of 5 by from Best Fix EverI WAS NEEDING SOMETHING TO BE ABLE TO GET A 9-VOLT DC POWER FOR HOUR METERS FOR MY LAWN EQUIPMENT. THESE BATTERY HOLDER METAL CLIPS WORKED GREAT FOR THE PROJECT. I WAS ABLE TO MOUNT THEM WITH A DPST SWITCH, WHICH ENABLED ME TO TURN THE HOUR METER ON AND AT THE SAME TIME LET THE EQUIPMENT START. WHEN I SHUT THE SWITCH OFF THE HOUR METER STOPPED AND THE EQUIPMENT QUIT RUNNING. JUST WHAT I WANTED. THANK YOU FOR YOUR PRODUCT WHICH MADE MY PROJECT A WHOLE LOT EASIER.
Date published: 2008-04-28
Rated 4 out of 5 by from Great Construction and Great ProductThis is one of the best preform 9-volt battery clips on the market. Very easy to solder to and it holds the battery very securely. The only con is that the battery can be difficult to change, but that's a small inconvenience for a great product.
Date published: 2007-11-03
if i use two of theis would they work on a 2x25W at 4 Ohm TDA7492 Class-D Audio Amplifier Board Only
Asked by: kkkkkaaaaaiiiiii
They would work however 9 volt batteries do not have very much long term output capability, averaging 200-300 mAh per battery. this will not allow for much life span.
Date published: 2014-02-04
Customer projects that include: 9V Battery Holder Metal Clip
Manuals / Resources
Related Products
Varta 9V NiMH Rechargeable Battery
Part # 140-264
Digital Multimeter
Part # 390-730
Rayovac 9V Alkaline Battery 2-Pack
Part # 140-118
Customers Also Bought
