800 Hz High Pass 8 Ohm Crossover
Convenient crossovers that work great in any application requiring economical, flexible filtering.
266-470
Weight: 0.45 lbs.
IN STOCK
List Price$13.99
You Save27%
$10.19
Buy 4-up$9.71
Part # 266-470
Convenient crossovers that work great in any application requiring economical, flexible filtering. Also for use in car stereo installations with component speaker systems. Low pass, band pass, and high pass models complement woofers, midranges, and tweeters. Designed to be wired in-line between amp and speaker by using .205" disconnect terminals or soldering. The crossovers' compact size facilitates mounting virtually anywhere you desire.
Specifications: • Approximately 250 watts RMS • Type: High pass • Driver impedance: 8 ohm • Crossover frequency: 800 Hz • Roll off: 12 dB.
  • Crossover TypeHigh Pass
  • ConfigurationBoard Only
  • BrandParts Express
  • Part Number266-470
  • UPC844632074998
  • Product CategoryAssembled Passive Crossovers
    (3 Reviews)
  • Weight0.45 lbs.
View similar products to the 800 Hz High Pass 8 Ohm Crossover
in the Assembled Passive Crossovers product category.
800 Hz High Pass 8 Ohm Crossover is rated 4.6667 out of 5 by 3.
Rated 5 out of 5 by from Very good crossoverI bought two of these to use with a 6 1/2" Pyle sealed midrange and 12" woofer in two bass cabinets. They work very well. I have ordered two low pass filters for the woofers. Bar inductors are used, which are lower resistance than coils...not necessary with high pass filters, but are far better with low pass. Very nice indeed.
Date published: 2012-11-27
Rated 5 out of 5 by from Perfect.... what more would you need?Well I'm relatively new in the speaker building hobby, but idecided to get this for my first build. At first i couldnt tell it was working during frequency testing, but it really shined when it was ACUTALLY playing music. My Aurasound NSW1 (full/mid tweet) used to make horrible sounds when it got bassy, but not its crisp and clean, and hits the mids to highs really well.In my POV, it everything i needed for a really great price. Features.. dont know how a high pass could possibly have any more features to it unless it has variable x-over point controller or something xD
Date published: 2012-06-20
Rated 4 out of 5 by from Good crossover and very affordablePerforms well and is a good value!
Date published: 2010-03-04
Does anyone have the dimensions for this piece?
Asked by: savaemako
This crossover measures 5"L x 2"W x 1-1/2"H.
Date published: 2014-02-10
WOuld this work with compression driver?
Would this work safely with this driver:http://www.parts-express.com/pe/showdetl.cfm?partnumber=290-440
Asked by: A.M. Pro
Hello A.M. Pro,Your right on the money by considering this network for the Eminence PSD:3006-8.Yes, I will work perfectly!!.
Answered by: salvatore J
Date published: 2013-10-07
inductor rating
What is the inductor rating or value on this X-over?Thanks
Asked by: BBob
Hello BBob,This is a 800 High Pass network with a 12 db roll-off/slope for an 8 ohm woofer12 db slopes require use of a capacitor and inductance coil.Values for 800 Hz @ 12db:3.18300 mH coil ( amp-out+ to coil lead, coil out to + speaker terminal)12.4375 capacitor ( wire across speaker positive and negative terminals)
Date published: 2013-07-27
What is the capacitor value?
Asked by: Einric
The capacitor will be 16uF.
Answered by: RussR
Customer projects that include: 800 Hz High Pass 8 Ohm Crossover
