#8 x 1" Deep Thread Pan Head Screws Black 100 Pcs.
These sharp point, black oxide, Phillips pan head screws with coarse/deep threads are ideal for use with wood and MDF. Perfect for speaker building and driver mounting.
081-425
Weight: 0.4801 lbs.
IN STOCK
$3.25
Buy 10-up$2.90
Part # 081-425
Qty:  PK
These #8 x 1" sharp point, black oxide, Phillips pan head screws with coarse/deep threads are ideal for use with wood and MDF. Perfect for speaker building and driver mounting. 100 pcs. per package.
  • Screw TypePan Head
  • Screw Length1"
  • Thread#8
  • Construction MaterialSteel
  • Color / FinishBlack
  • BrandParts Express
  • Part Number081-425
  • UPC844632027321
  • Product CategoryScrews
  • Unit of MeasurePK
    (15 Reviews)
  • Weight0.4801 lbs.
View similar products to the #8 x 1" Deep Thread Pan Head Screws Black 100 Pcs.
in the Screws product category.
#8 x 1" Deep Thread Pan Head Screws Black 100 Pcs. is rated 4.9333 out of 5 by 15.
Rated 5 out of 5 by from Easy to use.Well designed screw. Hardness and driver fit is great.
Date published: 2014-04-30
Rated 5 out of 5 by from THE go to screw for most applicationsThis is the best, easiest to use screw around, no pilot hole is generally needed unless you are close to the edge of the cut-out. It is made from very hard steel and resistant to stripping when using a #2 bit.I use these for initial driver mounting even when I later use stainless or nickel plated for final finish. As has been mentioned, they can rust a bit over time, so be aware if it is exposed because they don't stay looking new forever.
Date published: 2013-08-04
Rated 4 out of 5 by from Great griping capability. After 4 1/2 years, some some rust on heads.I finished building my Mini Statements in October 2008 and used these screws for all the drivers, they grip fantastic in MDF.I bought these mainly because of the deep thread but also partially because they are already black.When I pulled my grills off this spring to move my speakers I noticed that some of the screw heads had surface rust developing on them, amazingly, none of it was in the Phillips slots. Good thing they came in a pack of 100, the ones I left in the bag were fine, just swapped them out.Still, despite the minor rust (after 4.5 years mind you),I still recommend using these.
Date published: 2013-06-17
Rated 5 out of 5 by from Bye bye drywall screws!!!!Black finish is great. Price is right. Dont think twice, you need this screws.I dont work for PE.Hehe...
Date published: 2012-10-09
Rated 5 out of 5 by from excellent all around speaker screwnice black screws,no complaints, use for all kinds of speaker projects, just wish PE offered a larger selection of different types like tapered heads.
Date published: 2012-06-03
Rated 5 out of 5 by from Not just for speakersI have used these in most of my speaker projects and they do the job great even with my heavier sub drivers. Never had one strip or break and they look and hold up better then anything I can find at local hardware stores. Even used them to fix my kitchen cabnets when the original screws pulled out of the wood.
Date published: 2011-04-04
Customer projects that include: #8 x 1" Deep Thread Pan Head Screws Black 100 Pcs.
