300-581_ALT_0
300-581_ALT_1
300-581_ALT_2
300-581_ALT_3
300-581_ALT_4
300-581_ALT_5
300-581_ALT_6
8" Wireless Subwoofer Package - Dayton Audio SUB-800 8" 80W Powered Subwoofer + Sub-Link XR
Positioning your subwoofer just got easier, with the Dayton Audio wireless subwoofer package. Two great products come together to add punchy, clean bass to your home theater setup. Installation is easy and the results will blow you away.
  • 80 watt self-powered 8" subwoofer with wireless transmitter and receiver
  • Downward-firing flared port design for clean, powerful bass
  • Selectable "Auto-on" mode
  • Perfect for small home theaters or listening rooms
  • All audio and power cables included for wireless signal transfer
300-581
Weight: 27.0000 lbs.
IN STOCK
List Price$219.99
You Save45%
$119.00
Part # 300-581
Your subwoofer setup no longer has to be limited by long cables. With the Dayton Audio wireless subwoofer package, you can place your subwoofer anyplace there is an AC outlet. The setup is simple; just plug the included 3.5 mm to RCA stereo cable into the line out of your receiver and connect it to the Sub-Link XR transmitter.
The transmitter can be powered by the included USB cable/AC adapter, or directly by a USB port on your receiver. Next, place the subwoofer near any outlet within 40 ft. line-of-sight and connect the Sub-Link XR receiver. This can be powered the same way as the transmitter. Connect the receiver to the subwoofer using the included stereo or mono RCA cable. Now, pair the transmitter to the receiver and you are ready to go.
Subwoofer Specifications: • Power output: 80 watts RMS • Frequency response: 40-140 Hz • Box design: Ported • Inputs: RCA line level & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave • Phase switch • Auto on/off • Power requirements: 120 VAC, 60 Hz • Dimensions: 12-3/4" H x 12-3/16" W x 14-3/8" D.
Sub-Link XR Specifications: • Transmitter / Receiver operating voltage: 5V DC, 1A • RF frequency band: 2.404 to 2.467 GHz • Modulation: GFSK • Working distance: 12 meters (40 feet; unobstructed line-of-sight) • Transmitter power: ≤ 10 dBm • Transmitter input sensitivity: 700 mV @ 1% THD • Receiver sensitivity: -85 dBm • Frequency response: 15 to 20,000 Hz +1/-3 dB • Delay time: <25ms • THD+N: -60 dB @ 1 kHz. • Dimensions per Unit: 2-5/8/" L x 2" W x 1/2" H.
8" Wireless Subwoofer Package - Dayton Audio SUB-800 8" 80W Powered Subwoofer + Sub-Link XR includes the following items:
Qty Part # Item
1300-580Dayton Audio Sub-Link XR 2.4 GHz Wireless Audio Transmitter Receiver System for Subwoofers
1300-627Dayton Audio SUB-800 8" 80 Watt Powered Subwoofer
  • BrandDayton Audio
  • Part Number300-581
  • UPC848864017150
  • Product CategoryPowered Subwoofers
  • Weight27.0000 lbs.
View similar products to the 8" Wireless Subwoofer Package - Dayton Audio SUB-800 8" 80W Powered Subwoofer + Sub-Link XR
in the Powered Subwoofers product category.
Will this sub work using the 2-channel line outs from my Dish receiver and then hooked up to the transmitter? My TV has no line output. Thanks!
Asked by: William1945
Yes this will work using the line outputs like that.
Date published: 2014-10-24
Does this have an aux input
Asked by: mig321
This will accept any line level input via 3.5mm adapter cables included with the Sub-Link.
Date published: 2014-05-20
Customer projects that include: 8" Wireless Subwoofer Package - Dayton Audio SUB-800 8" 80W Powered Subwoofer + Sub-Link XR
