BUNDLE
300-581_ALT_0
300-581_ALT_1
300-581_ALT_2
300-581_ALT_3
300-581_ALT_4
300-581_ALT_5
300-581_ALT_6
8" Wireless Subwoofer Bundle - Dayton Audio SUB-800 8" 80W Powered Subwoofer + Sub-Link XR
Brand:|Part # 300-581
Positioning your subwoofer just got easier, with the Dayton Audio wireless subwoofer package. Two great products come together to add punchy, clean bass to your home theater setup. Installation is easy and the results will blow you away.
List Price$219.99
You Save37%
$139.50
Part # 300-581
  • 80 watt self-powered 8" subwoofer with wireless transmitter and receiver
  • Downward-firing flared port design for clean, powerful bass
  • Selectable "Auto-on" mode
  • Perfect for small home theaters or listening rooms
  • All audio and power cables included for wireless signal transfer
Your subwoofer setup no longer has to be limited by long cables. With the Dayton Audio wireless subwoofer package, you can place your subwoofer anyplace there is an AC outlet. The setup is simple; just plug the included 3.5 mm to RCA stereo cable into the line out of your receiver and connect it to the Sub-Link XR transmitter.
The transmitter can be powered by the included USB cable/AC adapter, or directly by a USB port on your receiver. Next, place the subwoofer near any outlet within 40 ft. line-of-sight and connect the Sub-Link XR receiver. This can be powered the same way as the transmitter. Connect the receiver to the subwoofer using the included stereo or mono RCA cable. Now, pair the transmitter to the receiver and you are ready to go.
Subwoofer Specifications: • Power output: 80 watts RMS • Frequency response: 40-140 Hz • Box design: Ported • Inputs: RCA line level & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave • Phase switch • Auto on/off • Power requirements: 120 VAC, 60 Hz • Dimensions: 12-3/4" H x 12-3/16" W x 14-3/8" D.
Sub-Link XR Specifications: • Transmitter / Receiver operating voltage: 5V DC, 1A • RF frequency band: 2.404 to 2.467 GHz • Modulation: GFSK • Working distance: 12 meters (40 feet; unobstructed line-of-sight) • Transmitter power: ≤ 10 dBm • Transmitter input sensitivity: 700 mV @ 1% THD • Receiver sensitivity: -85 dBm • Frequency response: 15 to 20,000 Hz +1/-3 dB • Delay time: <25ms • THD+N: -60 dB @ 1 kHz. • Dimensions per Unit: 2-5/8/" L x 2" W x 1/2" H.
8" Wireless Subwoofer Bundle - Dayton Audio SUB-800 8" 80W Powered Subwoofer + Sub-Link XR includes the following items:
Qty Part # Item
1300-580Dayton Audio Sub-Link XR 2.4 GHz Wireless Audio Transmitter Receiver System for Subwoofers
1300-627Dayton Audio SUB-800 8" 80 Watt Powered Subwoofer
  • Woofer Diameter8"
  • BrandDayton Audio
  • Part Number300-581
  • UPC848864017150
  • Product CategoryPowered Subwoofers
    (2 Reviews)
  • Weight27.0000 lbs.
View similar products to the 8" Wireless Subwoofer Bundle - Dayton Audio SUB-800 8" 80W Powered Subwoofer + Sub-Link XR
in the Powered Subwoofers product category.
8" Wireless Subwoofer Bundle - Dayton Audio SUB-800 8" 80W Powered Subwoofer + Sub-Link XR is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Great 8" sub woofer..wirelessBlue tooth is the cat's meow. What a simple set-up. And what an addition to a new receiver. Really enhances the 5.1 system. Highly recommend.
Date published: 2015-11-08
Rated 5 out of 5 by from WowI can't say enough about this combo. As stated in reviews by others the 8" sub sounds fantastic for its size and price. I've owned larger paradigm subs in the past and this one definitely keeps up with bass accuracy. SPL may not be as high but the overall product is very impressive. The wireless Sub-Link XR adapters work flawlessly as well and carry the signal without any noticeable lag. It connected immediately upon powering up with no drops yet. WiFi compatibility was of concern at first but after extensive testing I can say it's a non-issue.
Date published: 2015-01-03
  • 2016-02-12T06:16CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_300-581, PRD, sort_mostRecent
Is it Bluetooth compatible?
Asked by: trey50
This is not Bluetooth compatible.
Date published: 2015-10-06
I have a klipsch r10b sound bar. it has a sub transmitter for wireless. will it work with this sub wirelessly ?
Asked by: dandaman
The Klipsch wireless system is proprietary to their product, and probably will not automatically communicate with the SUB-LINK XR package. If your sound bar has a separate output on the back for connecting a wired subwoofer, you can use that output to provide an audio signal to the SUB-LINK XR transmitter, which will then transmit to its matching receiver, and you will still be able to achieve wireless signal transfer using the Dayton Audio hardware.
Answered by: DaytonAudio_Rory
Date published: 2015-05-31
Will this sub work using the 2-channel line outs from my Dish receiver and then hooked up to the transmitter? My TV has no line output. Thanks!
Asked by: WRM45
Yes this will work using the line outputs like that.
Does this have an aux input
Asked by: mig321
This will accept any line level input via 3.5mm adapter cables included with the Sub-Link.
  • 2016-02-12T06:58CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_300-581, PRD, sort_recentQuestionsFirst
