300-020_ALT_0
300-020_ALT_1
300-020_ALT_2
8" Ceiling Speaker with 70V Transformer
A full range, wide dispersion loudspeaker ideally suited to voice and background music. 12 oz. ceramic magnet, 1" aluminum voice coil. Includes pre-installed 70V line-matching transformer.
$9.90
Buy 4-19 $9.50
Buy 20+$8.50
Part # 300-020
A full range, wide dispersion loudspeaker ideally suited to voice and background music. 12 oz. ceramic magnet, 1" aluminum voice coil. 8 ohm impedance. Capable of handling 10 watts RMS, 20 watts maximum input. Response: 45-15,000 Hz. EIA standard 4 hole mounting. Includes pre-installed 70V line-matching transformer.
Also available without 70V line-matching transformer.
  • Input Rating70V
  • Mounting StyleIn-ceiling
  • Woofer Diameter8"
  • BrandParts Express
  • Part Number300-020
  • UPC844632036835
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
    (7 Reviews)
  • Weight2.5 lbs.
View similar products to the 8" Ceiling Speaker with 70V Transformer
in the In-Ceiling / On-Ceiling Speakers product category.
8" Ceiling Speaker with 70V Transformer is rated 4.2857 out of 5 by 7.
Rated 4 out of 5 by from Good value!I bought 12 of these speakers to add to an existing PA system. I am pleased with their performance so far, however I have 2 criticisms to offer: First; on several speakers the transformer leads were not properly soldered to the speaker terminals & came adrift--a minor inconvenience to resolder & check all the others. Second, the speaker metal frames are very light weight, so they easily distort if attached to a baffle which is not perfectly flat. Another thing to check before & after installation.However, once I fixed my baffles which were not flat, the speakers sounded great. A good value at this very low price!
Date published: 2014-06-16
Rated 4 out of 5 by from Worked better than expectedI purchased 34 of the speakers for a show. I built simple housings for mounting. We placed 8 configured as 10w in two buildings that each measured 100' x 80' each. Each building had a Bogen 100W amp. I placed 18 configured as 5W to cover a 300' x 100' on a Bogen 125W amp. The speakers worked well for the paging system as the were very clear. Compliments were given on the system clarity by participants in the show.
Date published: 2014-06-13
Rated 5 out of 5 by from Works well.Works well as a replacement for with M&S Systems M602 intercom ceiling speaker.
Date published: 2014-01-21
Rated 5 out of 5 by from Inexpensive replacement speaker for paging & background music.Purchased almost 100 of these for a system upgrade for zone paging in an industrial setting. Due to the price, we were able to provide to the customer a complete new unit instead of just adding the matching transformer. The quality is excellent for the price. Zero defects in our batch as well.
Date published: 2011-11-30
Rated 4 out of 5 by from Very cost effective ceiling speakerThese are very efficient speakers. You will find that running off the lower taps still gives you a ton of output! To ensure a vibration-free lifespan, I pulled the transformers off, and pop-riveted them back on using a piece of rubber gasket as a cushion...works like a charm. I am VERY happy with the speaker's fidelity too. I would buy them again.
Date published: 2009-06-01
Rated 4 out of 5 by from Easy To Use-Great Performance And Value.Needed a replacement eight-inch with transformer. PE had what I was looking for at a great price. This little speaker is perfect for all sorts of signal input, voice, BG music, or choir singers.Good overall frequency response.
Date published: 2009-04-30
  • 2015-07-30T06:33CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_7
  • loc_en_US, sid_300-020, PRD, sort_mostRecent
do covers come with purchase? what amp do you recommend and i also need a mic for anouncements
Asked by: oscar454
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-02-27
I hope to use this to replace a 45 ohm speaker in my M&S intercom system. I understand that the overall speaker volume is determined by which tap is used but is that the only consideration when choosing? Will connecting the wrong tap damage my system?
Asked by: Option
If the original speaker uses a 70V/100V line matching transformer then you might be able to use this speaker instead. If the original speaker does not have a 70V line matching transformer then this 70V transformer equipped speaker would not be an appropriate replacement. The combined wattage of all the speakers in the system (the "tap" selection of all speakers added together) should be less than the power output available from your amplifier.
Answered by: DaytonAudio_Rory
Date published: 2014-11-25
How do you mount these on the ceiling?
Asked by: Scooch
These speakers are usually mounted to a grill or an on-wall baffle like in the links below.http://www.parts-express.com/12-white-round-commercial-ceiling-speaker-grill--300-070http://www.parts-express.com/atlas-sound-417-8wd-8-wood-baffle-slope-front--242-860
Date published: 2015-06-01
What are the wattages the transformer is wired for  70v?
Asked by: Joon
Tap settings are .625w, 1.25w, 2.5w, 5w and 10w @ 70v.
  • 2015-07-30T07:59CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_300-020, PRD, sort_recentQuestionsFirst
