300-044_ALT_0
70V 30 Watt Speaker Volume Control Attenuator Wall Plate
Brand:|Part # 300-044
Controls the volume of 70 volt line PA speakers via a 10 step detented control. Wall plate features a white-finish stainless steel face and fits most standard single-gang electrical junction boxes. Screw type connectors accept up to 14 gauge wire for ease of installation.
List Price$25.99
You Save19%
$20.94
Buy 10+$19.10
Part # 300-044
Controls the volume of 70 volt line PA speakers via a 10 step detented control. Wall plate features a white-finish stainless steel face and fits most standard single-gang electrical junction boxes. Screw type connectors accept up to 14 gauge wire for ease of installation. Frequency response: 35-20,000 Hz. Power rating: 30 watts RMS.
  • BrandParts Express
  • Part Number300-044
  • UPC844632014420
  • Product CategoryAttenuators / Auto-Transformers
    (3 Reviews)
  • Weight0.7 lbs.
View similar products to the 70V 30 Watt Speaker Volume Control Attenuator Wall Plate
in the Attenuators / Auto-Transformers product category.
70V 30 Watt Speaker Volume Control Attenuator Wall Plate is rated 4.6667 out of 5 by 3.
Rated 5 out of 5 by from 70V level controlthe volume controls are typical of the brand, work great sound good. very good looking part as well.
Date published: 2015-06-10
Rated 4 out of 5 by from not bad at all for the pricethe volume control is really good. I have three of them installed in a restaurant audio and it has been working great. The only thing that I don't like about it is that is that the volume is controlled in an exponentially way instead of linear. For instance, when you turn the volume up slightly, there is no volume gain, but if you go one step higher, then the sound is too loud. I found a way around that in balancing the volume between the amp and the VC.
Date published: 2012-11-21
Rated 5 out of 5 by from great price, good productneeded this for a resturaunt installation.
Date published: 2008-12-24
  • 2016-02-14T06:42CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_300-044, PRD, sort_mostRecent
Hi, this is for stereo applications, correct? I have two speakers (L and R) over a jacuzzi and this volume control will do both?
Asked by: jdmc
This is only designed for 70v systems, not 8 ohm systems. If you are looking to control a pair of 8 ohm speakers you will want to look at something like this:http://www.parts-express.com/wired-home-csvc50-impedance-matching-rotary-speaker-volume-control-50w--300-560
Date published: 2016-01-25
Want to replace the ones I have. On back of existing is a CH1 with 4 terminals and a CH2 with 4 terminals on a box on back of switch with the following printed on it. AT-50H  Violet  L-8(ohm symbol)  Will the #300-044 work in place of existing?
Asked by: dorman
Date published: 2015-01-20
Is this control have a transformer ? The Input is the 70V line but what is the output to the speaker ? low Z ? Do we have to bypass the transformer at the enclosure ?
Asked by: YoRi
Yes this has a transformer but it does not take the place of the transformer on the speaker or at the amplifier. This has a simple +/- input and +/- output to be used in line with a 70V speaker.
Date published: 2014-02-24
What's the mounting depth ??
Asked by: Ward
This product has a mounting depth of 2".
Answered by: RussR
Date published: 2012-04-13
  • 2016-02-14T07:39CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_300-044, PRD, sort_recentQuestionsFirst
