70V 15W Line Matching Transformer
Constant voltage, isolated line matching transformer for use with public address amplifiers utilizing a 70.7 volt carrier line for sound transmission. Frequency response: 40-20,000 Hz. Secondary impedance: 4 or 8 ohms.
300-039
Weight: 0.9 lbs.
IN STOCK
$6.25
Buy 10-up$5.79
Part # 300-039
Constant voltage, isolated line matching transformer for use with public address amplifiers utilizing a 70.7 volt carrier line for sound transmission. Frequency response: 40-20,000 Hz. Secondary impedance: 4 or 8 ohms. Tap at 5 W, 7.5 W, 10 W and 15W. Minimum efficiency: 80%. Mounting holes: 2.75" (center to center).
  • BrandParts Express
  • Part Number300-039
  • UPC844632014437
  • Product CategoryLine-Matching Transformers
    (13 Reviews)
  • Weight0.9 lbs.
View similar products to the 70V 15W Line Matching Transformer
in the Line-Matching Transformers product category.
70V 15W Line Matching Transformer is rated 4.5385 out of 5 by 13.
Rated 5 out of 5 by from Works GreatWe buy these often and they are easy to assemble and well worth the price. Nothing but good things to say about this product.
Date published: 2014-03-05
Rated 4 out of 5 by from Nice TransformerI was surprised how nice this transformer is compared to others. It's labeled, so no need to carry around a reference when using a bunch of these. I bought two of these to use with ceiling speakers that already had transformers on them. Very good deal.
Date published: 2012-03-09
Rated 5 out of 5 by from Used to match 600 ohm output to a 3.2 ohm speakerI used this transformer to match the output of an older tube short wave receiver. The radio has 600 ohms out. I measured the turns ratio and then calculated which taps would match the best. I used the 5 watt input tap and the 8 ohm output tap. The transformer works fine and the sound on the old tube radio is great.
Date published: 2012-02-26
Rated 5 out of 5 by from Great cheap transformerPut these on some 8 ohm horns for a bowling center pit call system. Worked like a charm and loud too! Although one was bad when I got it parts express replaced it free of charge and shipped it fast too! Would highly reccomend to anyone building a 70v pa system
Date published: 2012-02-16
Rated 5 out of 5 by from Worked like a champAlthough they never transformed into a new Camaro, they did sound pretty good.
Date published: 2009-09-30
Rated 5 out of 5 by from Good valueI needed a 600 ohm to 8 ohm xfmr for some old military gear. This worked great.
Date published: 2009-08-28
What are the dimensions?
Can someone please post the dimensions for these transformers, both with and without the mounting brackets. I need to know if they will fit mounted upright into part #320-718
Asked by: albrittbrat
The transformer body is 2-3/8" wide, 2" high and 1-7/8" thick when measuring the coil itself. The mounting tabs add an inch to the overall width.
Date published: 2014-04-11
Customer projects that include: 70V 15W Line Matching Transformer
