70V 10W Line Matching Transformer
Constant voltage, isolated line matching transformer for use with public address amplifiers utilizing a 70.7 volt or 25 volt carrier line for sound transmission. Frequency response: 100-12,000 Hz. Secondary impedance: 4 or 8 ohms. Tap at 0.62W, 1.25W, 2.5W, 5W and 10W.
300-040
Weight: 0.8778 lbs.
IN STOCK
$4.90
Buy 10-up$4.45
Part # 300-040
Constant voltage, isolated line matching transformer for use with public address amplifiers utilizing a 70.7 volt or 25 volt carrier line for sound transmission. Frequency response: 100-12,000 Hz. Secondary impedance: 4 or 8 ohms. Tap at 0.62W, 1.25W, 2.5W, 5W and 10W. Minimum efficiency: 77%. Mounting holes: 2.4" (center to center). Dimensions: 2-3/4" L x 1-1/2" W x 1-9/16" D.
  • BrandParts Express
  • Part Number300-040
  • UPC844632010170
  • Product CategoryLine-Matching Transformers
    (10 Reviews)
  • Weight0.8778 lbs.
View similar products to the 70V 10W Line Matching Transformer
in the Line-Matching Transformers product category.
70V 10W Line Matching Transformer is rated 4.5 out of 5 by 10.
Rated 5 out of 5 by from Good DealThis little thing rocks. But be careful you must hook up both grounds in order for this thing to work.
Date published: 2011-03-12
Rated 3 out of 5 by from Good Value - worked wellproduct arrived and was satisfactory in meeting printed description and performance in the application.
Date published: 2009-11-11
Rated 4 out of 5 by from This product worked wellThe transformer was easy to install and worked well.
Date published: 2009-06-26
Rated 4 out of 5 by from Good productPerfect fit, proper taps, worked just fine.
Date published: 2008-10-02
Rated 5 out of 5 by from Best of bothNot only do you get all the typical 70V selections, but this transformer can also be used to 25V systems as well. NOTE: The labels are not always lined up directly over the denoted wires. It's best to look closely and count them.
Date published: 2008-09-12
Rated 5 out of 5 by from Just what I needed.Parts Express helped me choose this product and it works like a charm on all the speakers in my system.
Date published: 2008-03-31
  • 2015-03-03T06:28CST
  • co_hasreviews, tv_0, tr_10
  • loc_en_US, sid_300-040, PRD, sort_mostRecent
What are the dimensions, operating temperature range?
Asked by: Jackski
The overall dimensions are 2-3/4" L x 1-1/2" W x 1-9/16" D and the operating temperature range is -15℃~40℃.
Date published: 2015-01-15
Can this be used with a 45 ohm driver on 25V or 70V systems, if so what is the recommended tap settings for 1 or 2 watts?
Intended use is retrofitting a commercial intercom system as a simple distributed sound system. These would replace simple 150 ohm resistors at the speaker end. No other controls are present in the system.
Asked by: tjbaudio
This transformer only has options for 4 and 8 ohm secondary impedance. I would not recommend using it with any other impedances.
Answered by: Chrisf
Date published: 2013-04-24
300-040 explanation of color leads
I bought two 300-040 70.7V line matching transformers and there is no sheet with them that explains the function of the color leads. I need to know how they are connected internally and what their function is.
Asked by: Joe S
This transformer is designed to be used with 25 and 70 volt speaker systems. The input leads are called "tap settings" and these determine how loud the speaker will play. The higher the tap setting, the louder the playback. You will be connecting the negative speaker wire to the "Common" or black lead. The positive will be connected to one of the tap settings, the others can be removed. The speaker side of the transformer has 8 ohm, 4 ohm and common leads. The negative of the speaker gets connected to the common or black lead, and the positive gets connected to either the 4 or 8 ohm leads, depending on the impedance of the speaker.The colors are as follows: Gray = 8 ohms, White = 4 ohms, Black = Common, Purple = 70V - 0.62W, Orange = 70V - 1.25W, Brown = 70V - 2.5W, Red = 25V - 0.62W / 70V - 5W, Blue = 25V - 1.25W / 70V - 10W, Yellow = 25V - 2.5W, Green = 25V - 5W, White = 25V - 10W, Black = Common.
Date published: 2013-05-15
  • 2015-03-03T07:57CST
  • loc_en_US, sid_300-040, PRD, sort_recentQuestionsFirst
Customer projects that include: 70V 10W Line Matching Transformer
