299-004_ALT_0
299-004_ALT_1
7" Paper Cone Woofer with Blue Surround 6 Ohm
Brand:|Part # 299-004
Repair or build your own bookshelf, satellite, center channel or computer speakers using this 7" woofer and save over 50% off the original retail price. Quantities are extremely limited on this Parts Express exclusive buyout!
Part # 299-004
  • 6 ohm impedance is safe for use with nearly any amplifier
  • Blue foam surround ads visual appeal
  • 3.5 mm of Xmax and 88 dB SPL
This 6 ohm, 7" woofer with blue surround was designed for use in home theater speakers, and is great for use in sealed, compact enclosures as bookshelf, center channel, and satellite speakers. The 6 ohm impedance extracts more power than a standard 8 ohm speaker, increasing output. This speaker also includes an oversized trim ring to add the finishing cosmetic touch to your speakers.
Alternatively, you can repurpose this woofer as a midrange/midbass speaker in larger 3-way cabinets. Save over 50% off the original retail price through this Parts Express exclusive buyout. Quantities are extremely limited, act fast!
  • Nominal Diameter7"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance6 ohms
  • Frequency Response80 to 5,000 Hz
  • Sensitivity88 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)88 Hz
  • DC Resistance (Re)4.27 ohms
  • Voice Coil Inductance (Le)0.94 mH
  • Mechanical Q (Qms)4.07
  • Electromagnetic Q (Qes)1
  • Total Q (Qts)0.81
  • Compliance Equivalent Volume (Vas)0.23 ft.³
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter7"
  • Baffle Cutout Diameter5.75"
  • Depth3"
  • Bolt Circle Diameter6.25"
  • # Mounting Holes4
  • Sealed Volume0.68 ft.³
  • Sealed F389 Hz
  • Vented Volume0.94 ft.³
  • Vented F351 Hz
  • BrandFactory Buyouts
  • Part Number299-004
  • UPC848864012537
  • Product CategoryWoofers
  • Weight2.2000 lbs.
View similar products to the 7" Paper Cone Woofer with Blue Surround 6 Ohm
