7-1/2" Paper Cone Woofer 8 Ohm
Brand:|Part # 299-005
Repair or build your own bookshelf, satellite, center channel or computer speakers using this 7" paper cone woofer and save over 40% off the original retail price. Quantities are extremely limited on this Parts Express exclusive buyout!
Part # 299-005
  • 3-layer 1" voice coil
  • 7-1/2" oversized trim ring
  • Works well in small, sealed enclosures
Frequently Bought Together
This 7" paper woofer with foam surround was designed for use in home theater speakers, and is great for use in small sealed enclosures as bookshelf, center channel, and satellite speakers. An oversized, 7-1/2" trim ring allows this woofer to be used in cabinets with a larger than normal cutout. A three-layer 1" voice coil on an aluminum former increases power handling to a respectable 50 watts RMS.
Alternatively, you can repurpose this woofer as a midrange/midbass speaker in larger 3-way cabinets or even as a car audio speaker. Save over 40% off the original retail price through this Parts Express exclusive buyout. Quantities are extremely limited, act fast!
  • Nominal Diameter7"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response90 to 5,000 Hz
  • Sensitivity83 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)96.9 Hz
  • DC Resistance (Re)6.96 ohms
  • Voice Coil Inductance (Le)0.76 mH
  • Mechanical Q (Qms)4.22
  • Electromagnetic Q (Qes)2.19
  • Total Q (Qts)1.44
  • Compliance Equivalent Volume (Vas)0.13 ft.³
  • Maximum Linear Excursion (Xmax)2 mm
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.5"
  • Baffle Cutout Diameter5.75"
  • Depth2.375"
  • Bolt Circle Diameter6.875"
  • # Mounting Holes4
  • Sealed Volume0.17 ft.³
  • Sealed F389 Hz
  • Vented Volume1.59 ft.³
  • Vented F352 Hz
  • BrandFactory Buyouts
  • Part Number299-005
  • UPC848864012490
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (1 Reviews)
  • Weight1.4 lbs.
View similar products to the 7-1/2" Paper Cone Woofer 8 Ohm
