680uF 16V High Temp Radial Capacitor
Brand:|
High temperature electrolytics for use in switch mode power supplies found in TVs, VCRs, etc. 105° C operating temperature satisfies characteristic W of JIS-C-5141 standards. ± 20% tolerance.
  • Standard aluminum electrolytic capacitor series for general purpose
  • -40°C ~ +105°C temperature range
  • RoHS Compliance
020-1712
Weight: 0.0066 lbs.
IN STOCK
$0.66
Buy 10-99 $0.50
Buy 100-up$0.33
Part # 020-1712
Specifications: • Dimensions: 10 x 20 mm.
Note: Xicon is phasing out their line of electrolytic capacitors; therefore, we are transitioning to the Lelon brand. Rest assured that whatever brand you receive, your Xicon or Lelon capacitor will have comparable dimensions, equivalent specifications, and RoHS compliance.
  • Capacitance680 µF
  • Voltage Rating16V
  • Tolerance20%
  • Termination StyleRadial
  • BrandLelon
  • Part Number020-1712
  • UPC844632050916
  • Product CategoryHigh Temperature Electrolytic Capacitors
    (6 Reviews)
  • Weight0.0066 lbs.
View similar products to the 680uF 16V High Temp Radial Capacitor
in the High Temperature Electrolytic Capacitors product category.
680uF 16V High Temp Radial Capacitor is rated 4.8333 out of 5 by 6.
Rated 5 out of 5 by from Capacitors Worked GreatI had a Panasonic video hard drive and DVD recorder that stopped working. I saw the power supply had two bulging capacitors and replaced them with ones from Parts-Express. The video recorder now works fine.
Date published: 2014-04-24
Rated 5 out of 5 by from Great ProductA great quality replacement for any applacation as good as you can get any where and at a price that can't be matched without waiting for weeks. PE keeps a good stock of what you need Thanks PE for fast shipping
Date published: 2012-01-12
Rated 5 out of 5 by from Like Plug and PlayI was a little skeptical about ordering from this web site, but when my order came in so quickly and the product worked without any trouble, I am sold. Definitely will order from Parts Express again. the value is well worth it. Thank you.
Date published: 2011-09-26
Rated 4 out of 5 by from Did the trickThe Panasonic EH80 fired right up after I put everything back together. These caps wear out over time, causing them to ultimately fail. These two are in parallel, which is why they both pretty much go at the same time.
Date published: 2009-06-29
Rated 5 out of 5 by from Worked FineI used these to replace other failed capacitors on a Panasonic DVR that belongs to my friend. They were shipping in a padded envelope and arrived in working order.Otherwise, Parts-Express.com shipped the order as I had requested. I'll shop here first next time around.
Date published: 2008-12-21
Rated 5 out of 5 by from So Far So Good ....Wonderfully fast delivery and excellent pricing -- you can't beat first class shipping for low cost. The capacitors dropped right in -- all appeared to be excellent quality ... but so did the originals and they blew up in about 3 years. The bottom line is I can't tell what shape these will be in in a few years, but after a month I couldn't be happier. The manufacturer was on the "good capacitor" list, so I'm optimistic. But I'm definitely satisfied with PartsExpress!
Date published: 2008-04-13
Customer projects that include: 680uF 16V High Temp Radial Capacitor
