6 Pin Mini DIN Plug
6 Pin Mini DIN Plug
6 pin mini, male DIN connector. Sold individually.
090-620
Weight: 0.0013 lbs.
IN STOCK
$1.39
Buy 10-99 $1.28
Buy 100-up$0.98
Part # 090-620
6 Pin Mini DIN Plug
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • Conductors6-Pin
6 Pin Mini DIN Plug
  • BrandParts Express
  • Part Number090-620
  • UPC038975141060
  • Product CategoryDIN & Mini DIN Connectors
    (12 Reviews)
  • Weight0.0013 lbs.
View similar products to the 6 Pin Mini DIN Plug
in the DIN & Mini DIN Connectors product category.
6 Pin Mini DIN Plug
6 Pin Mini DIN Plug is rated 4.5 out of 5 by 12.
Rated 5 out of 5 by from "APART FROM THE REST!"In a fluke accident I broke my DIN pin on a KLIPSCH subwoofer! I was bummed out...found a link and referral for PARTS EXPRESS via google and thought I'd give it a shot. Parts arrived on time packaging was fine. I have novice to intermediate solder skills. The pin itself was reliable, well made, no rough edges or burrs. It actually came apart into 3 pieces, which made soldering and installation much more accurate and easy!In summary, I LOVE PARTS EXPRESS!!!
Date published: 2014-03-07
Rated 5 out of 5 by from First time using a 6-Pin DINThis is the first time I've every tried to build my own cable, so it was a little tricky to figure out how to first open it and then solder the connectors. The reverse side of the connector, I discovered, has hollow tubes to allow you to insert the lead and let the solder fill the rest of the space. As far as I can tell, it's a good product.
Date published: 2014-03-03
Rated 5 out of 5 by from 6 pin mini dinUsed this to repair a Pro Media Speaker System by Klipsch and this is a very inexpensive repair. As the pin description it is small so you really need to know how to solder in small places. Product was just as described and speakers work like new.
Date published: 2013-02-07
Rated 4 out of 5 by from Very SatisfiedThis product was easy to assemble and use. The pins do not take much heat so caution should be used when soldering.
Date published: 2010-03-24
Rated 4 out of 5 by from Easy to useTiny pins to solder, but good value.
Date published: 2009-12-09
Rated 5 out of 5 by from but yet another klipsch ownerread all the other reviews and they are dead on soldered up in no time in my opinion buy two in case you mess up the first time.
Date published: 2009-06-20
6 Pin Mini DIN Plug
How to get a wiring diagram to fix a plug.
Where do I get a 6 pin mini din plug wiring diagram so that I can match the wires to the pin? This is for a klipsch speaker system for my computer.
Asked by: Fun Frank
If you search (Google, etc) "6-pin mini DIN diagram" you will receive dozens of useful references on this and related DIN connectors.With that overview in mind, then go to : http://forums.klipsch.com/forums/t/110556.aspx where you will find the wiring diagram specific to Klipsch speakers.
Answered by: FlyBoy
Date published: 2012-03-26
what type of solder do you use on these, solder paste?
novice at soldering, any advice is appreciated, but I want to fix these (2sets) promedias.
Asked by: RGWag
Just about any solder you're comfortable with should do the job. Given the application, a small diameter solder may be advisable, I've referenced one below for your convenience.
Answered by: RussR
Date published: 2011-07-08
Customer projects that include: 6 Pin Mini DIN Plug
6 Pin Mini DIN Plug
Part # 090-620
