6 Pin DIN Plug 240°
6 Pin DIN Plug 240 degree
6 pin DIN plug, 240°.
090-343
Weight: 0.0264 lbs.
IN STOCK
$1.29
Buy 10-99 $1.15
Buy 100-up$0.89
Part # 090-343
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • Conductors6-Pin
  • BrandParts Express
  • Part Number090-343
  • UPC038975145099
  • Product CategoryDIN & Mini DIN Connectors
    (2 Reviews)
  • Weight0.0264 lbs.
View similar products to the 6 Pin DIN Plug 240 degree
in the DIN & Mini DIN Connectors product category.
6 Pin DIN Plug 240 degree is rated 4.0 out of 5 by 2.
Rated 5 out of 5 by from DIN ConnectorsDelivery was fast and connectors met requirements. Care must be used in soldering these connectors; even with a variable temp iron used for SMD work one plug was damaged during assembly.
Date published: 2013-05-29
Rated 3 out of 5 by from Does the job but could be betterVery easy to solder and assemble, and fits well into standard 6-pin DIN jacks. My only complaint is that the outer plastic shell is soft and somewhat too large in diameter. It does not fit snugly and therefore can be pulled off easily. I put a couple wraps of electrical tape under it to make it fit more snugly, which seemed to do the trick.
Date published: 2013-03-31
Customer projects that include: 6 Pin DIN Plug 240 degree
Related Products
Customers Also Bought
