299-003_ALT_0
299-003_ALT_1
6" Paper Cone Woofer 8 Ohm
Brand:|Part # 299-003
Repair or build your own bookshelf, satellite, center channel or computer speakers using this 6" treated paper cone woofer and save over 50% off the original retail price. Quantities are extremely limited on this Parts Express exclusive buyout!
Part # 299-003
  • Treated foam surround
  • Works great as a woofer or midbass speaker
  • 66 Hz free-air resonance
This 6" treated paper woofer with foam surround was designed for use in home theater speakers. A low free air resonance of 66 Hz, combined with a Qts of 0.75 and Vas of 0.54, make this speaker great for use in both large ported and sealed tower-style enclosures. A 1" aluminum former provides great heat dissipation for the voice coil, creating good power handling.
Save over 50% off the original retail price through this Parts Express exclusive buyout. Quantities are extremely limited, act fast!
  • Nominal Diameter6"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response60 to 4,000 Hz
  • Sensitivity88 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)66 Hz
  • DC Resistance (Re)5.34 ohms
  • Voice Coil Inductance (Le)0.77 mH
  • Mechanical Q (Qms)2.92
  • Electromagnetic Q (Qes)1.01
  • Total Q (Qts)0.75
  • Compliance Equivalent Volume (Vas)0.54 ft.³
  • Maximum Linear Excursion (Xmax)2 mm
  • Cone MaterialTreated Paper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.8125"
  • Baffle Cutout Diameter4.5625"
  • Depth2.25"
  • Bolt Circle Diameter5.5"
  • # Mounting Holes4
  • Sealed Volume1.71 ft.³
  • Sealed F371 Hz
  • Vented Volume1.91 ft.³
  • Vented F340 Hz
  • BrandFactory Buyouts
  • Part Number299-003
  • UPC848864012520
  • Product CategoryWoofers
  • Weight1.0000 lbs.
View similar products to the 6" Paper Cone Woofer 8 Ohm
Part # 299-003
