299-977_ALT_0
299-977_ALT_1
6" Paper Cone Shielded Woofer 5 ohm
Brand:|Part # 299-977
Repair or build your own bookshelf, satellite, center channel or computer speakers using this 6" shielded, paper cone woofer and save 50% off the original retail price. Quantities are extremely limited on this Parts Express exclusive buyout!
Part # 299-977
  • High 89 dB output
  • Unique 5 ohm impedance for special applications
  • Shielded motor for close placement to sensitive electronics
This 6" shielded, paper woofer with foam surround was designed for use in home theater speakers, and is great for use in small sealed enclosures as bookshelf, center channel, and satellite speakers. The shielded motor also makes this woofer a great candidate for computer speakers that are placed closely to sensitive electronics. An oversized, 7-3/8" trim ring allows this woofer to be used in cabinets with a larger than normal cutout.
The 5 ohm impedance extracts more current from amplifiers for an increase in output over an 8 ohm variant. Wire two in series for a safe 10 ohm load when used in MTM configurations. Alternatively, you can repurpose this woofer as a midrange/midbass speaker in larger 3-way cabinets or even as a car audio speaker. Save 50% off the original retail price through this Parts Express exclusive buyout. Quantities are extremely limited, act fast!
  • Nominal Diameter6"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance5 ohms
  • Frequency Response90 to 3,000 Hz
  • Sensitivity89 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)83 Hz
  • DC Resistance (Re)4.49 ohms
  • Voice Coil Inductance (Le)1.07 mH
  • Mechanical Q (Qms)3.24
  • Electromagnetic Q (Qes)0.89
  • Total Q (Qts)0.7
  • Compliance Equivalent Volume (Vas)0.28 ft.³
  • Maximum Linear Excursion (Xmax)2 mm
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.375"
  • Baffle Cutout Diameter6.5"
  • Depth2.75"
  • Bolt Circle Diameter6.75"
  • # Mounting Holes4
  • Sealed Volume0.87 ft.³
  • Sealed F395 Hz
  • Vented Volume0.86 ft.³
  • Vented F351 Hz
  • BrandFactory Buyouts
  • Part Number299-977
  • UPC848864006468
  • Product CategoryProducts
  • Weight1.8 lbs.
View similar products to the 6" Paper Cone Shielded Woofer 5 ohm
in the Products product category.
