6-1/2" Subwoofer Speaker
Brand:|Part # 299-114
A beefy, well-built 6-1/2" driver for high-powered compact subwoofer or woofer applications.
Part # 299-114
  • Treated paper cone with rubber edge for accurate, controlled motion
  • Great Xmax and high power handling capability help deliver dynamic response
  • Stamped steel chassis with durable black finish
  • 1-1/2" diameter 4-layer copper voice coil on sturdy aluminum former
  • Flat spider, vented pole piece, large ceramic ferrite magnet structure with bumped back plate
  • Tough little driver for compact multimedia subs, or used in multiples
This 6-1/2" subwoofer speaker features a deep profile, long fiber, high-pulp cone finished beautifully in a protective coating that also dampens resonances. The 1-1/2" diameter 4-layer voice coil's 5/8" winding length maintains plenty of copper in the magnetic gap, ensuring plenty of high-impact, low-distortion output. A vented pole piece reduces performance-robbing power compression, and the magnet structure's extended back plate prevents "bottoming out" the long voice coil. Great subwoofer speaker for any design or application, particularly multimedia systems, small home theater setups, and multi-driver configurations. Buyout, limited quantities.
Specifications: *Power handling: 80 watts RMS/160 watts max *VCdia: 1-1/2" *Le: 1.61 mH *Impedance: 4 ohms *Re: 3.25 ohms *Frequency response: 35-2,000 Hz *Fs: 38 Hz *SPL: 83.5 dB 1W/1m *Vas: 0.55 cu. ft. *Qms: 6.74 *Qes: 0.64 *Qts: 0.59 *Xmax: 4.5 mm *Dimensions: Outside diameter: 6-1/2", Cutout diameter: 5-3/4", Depth: 3".
  • BrandFactory Buyouts
  • Part Number299-114
  • UPC844632095207
    (9 Reviews)
  • Weight2.7 lbs.
View similar products to the 6-1/2" Subwoofer Speaker
