6-1/2" Poly Cone Midbass Woofer 4 Ohm
Brand:|Part # 299-609
This buyout 6-1/2" woofer is the perfect replacement for worn, tired sealed bookshelf speakers. The extended frequency response allows it to mate well with tweeters without a low pass filter. Save nearly 60% off the original retail price through this Parts Express exclusive buyout.
List Price$26.00
You Save81%
Buy 25-79 $3.99
Buy 80+$3.20
Part # 299-609
  • Smooth, natural response doesn't require a low-pass filter
  • Decent Xmax for good bass response
  • Designed for use in sealed cabinets
  • Save nearly 60% off the original retail price!
This durable 6-1/2" poly cone woofer with rubber surround is designed to work best in small, sealed bookshelf-style cabinets. The damped poly cone creates smooth sound from 45 Hz all the way up to 3,000 Hz and is easy to integrate with many different tweeters, and the 4 ohm impedance extracts more current from an amplifier for twice the output (3 dB increase), when compared to a similar 8 ohm speaker.
A 1" voice coil is combined with an aluminum former for a power handling rating of 30 watts RMS and 60 watts max, and the "Q" of the motor is such that solid bass performance can be achieved in cabinets as small as 0.25 cubic feet, with an f3 of 63 Hz (with a 1/4 pound of acoustic fill).
Save over 50% off the original price through this exclusive factory buyout.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance4 ohms
  • Frequency Response50 to 6,000 Hz
  • Sensitivity88.3 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)52 Hz
  • DC Resistance (Re)3.37 ohms
  • Voice Coil Inductance (Le)0.48 mH
  • Mechanical Q (Qms)2.99
  • Electromagnetic Q (Qes)1.4
  • Total Q (Qts)0.95
  • Compliance Equivalent Volume (Vas)0.65 ft.³
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.5"
  • Baffle Cutout Diameter5.625"
  • Depth2.875"
  • Bolt Circle Diameter6.125"
  • # Mounting Holes4
  • Sealed Volume1.53 ft.³
  • Sealed F349 Hz
  • Vented Volume3.64 ft.³
  • Vented F330 Hz
  • BrandFactory Buyouts
  • Part Number299-609
  • UPC848864006864
  • Product CategoryWoofers
    (59 Reviews)
  • Weight1.8 lbs.
View similar products to the 6-1/2" Poly Cone Midbass Woofer 4 Ohm
