299-006_ALT_0
299-006_ALT_1
5" Paper Cone Midbass Shielded Woofer 8 Ohm
Brand:|Model: 1-2WF-12133 50|Part # 299-006
Repair or build your own bookshelf, satellite, center channel or computer speakers using this 5" shielded midbass woofer and save over 40% off the original retail price. Quantities are limited on this Parts Express exclusive buyout!
Part # 299-006
  • Treated foam surround
  • Works great as a woofer or midbass speaker
  • 85 Hz free-air resonance
This 5" treated paper midbass woofer with foam surround was designed for use in home theater speakers. A free air resonance of 85 Hz, combined with a Qts of 0.88 and Vas of 0.15, make this speaker great for use in both large ported and sealed tower-style enclosures. A 1" aluminum former provides great heat dissipation for the voice coil, creating good power handling.
Save over 40% off the original retail price through this Parts Express exclusive buyout. Quantities are extremely limited, act fast!
  • Nominal Diameter5"
  • Power Handling (RMS)25 Watts
  • Power Handling (max)50 Watts
  • Impedance8 ohms
  • Frequency Response85 to 6,000 Hz
  • Sensitivity85 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)85 Hz
  • DC Resistance (Re)6.45 ohms
  • Voice Coil Inductance (Le)0.72 mH
  • Mechanical Q (Qms)3.30
  • Electromagnetic Q (Qes)1.20
  • Total Q (Qts)0.88
  • Compliance Equivalent Volume (Vas)0.15 ft.³
  • Maximum Linear Excursion (Xmax)2 mm
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.1875"
  • Baffle Cutout Diameter4.0625"
  • Depth2.625"
  • # Mounting Holes4
  • Sealed Volume0.40 ft.³
  • Sealed F383 Hz
  • Vented Volume0.72 ft.³
  • Vented F349 Hz
  • BrandFactory Buyouts
  • Model1-2WF-12133 50
  • Part Number299-006
  • UPC848864012728
  • Product CategoryWoofers
    (7 Reviews)
  • Weight1.5500 lbs.
  • Warranty90 days
View similar products to the 5" Paper Cone Midbass Shielded Woofer 8 Ohm
