5" Braked Swivel Caster 250 Lb. Capacity
• 5" Braked Swivel Caster • Overall height: 5-3/4" • Top plate: 2-1/2" x 3-5/8" • Bolt hole pattern: 1-3/4" x 2-7/8" slotted to 3" • Ball bearing
  • 250 lb. Carrying capacity
  • Case hardened double ball raceways provide extra capacity & durability
  • Gray polyurethane on beige polyolefin wheel does not mark floors
  • 1-1/4" wide wheel for excellent traction & stability
262-092
Weight: 2.5 lbs.
IN STOCK
$14.82
Buy 10-up$13.66
Part # 262-092
The 3800 series of low-cost casters are perfect for equipment racks, bass bins, movie and soundstage equipment, or storage containers for the weekend band to the professional touring musician. Other applications include light-duty material handling equipment, food service carts & equipment, bakery racks & equipment, miscellaneous dollies, mobile cases, displays, mobile wire racking, stock carts, textile applications, warehouse & manufacturing applications, etc. Sold individually. • 5" Braked Swivel Caster • Overall height: 5-3/4" • Top plate: 2-1/2" x 3-5/8" • Bolt hole pattern: 1-3/4" x 2-7/8" slotted to 3" • Ball bearing
  • Caster TypeSwivel with Brake
  • Wheel Diameter5"
  • Color / FinishZinc
  • BrandParts Express
  • Part Number262-092
  • UPC844632035128
  • Product CategoryCasters
    (1 Reviews)
  • Weight2.5 lbs.
View similar products to the 5" Braked Swivel Caster 250 Lb. Capacity
in the Casters product category.
5" Braked Swivel Caster 250 Lb. Capacity is rated 1.0 out of 5 by 1.
Rated 1 out of 5 by from Not functional under load.There is "play" in the holes where the wheel axle bolt slides through the fork that holds the wheel. Under actual load (and under it's rated load for 4 wheels), the wheels and axle are pushed up in this room of "play" so the wheels grind and lock against the swivel bearing inside the top of the fork. This is the case for all 4 casters that I have. Only thing I have found to fix this is to tighten the bolts for the axles so much that the load won't budge it over time, but then the brake levers cannot be moved and become useless. I will try to put something (a washer perhaps) in the very small space where there's play, but I was not expecting to have to do this. I opted for the 5" wheel because I thought bigger was better but there is no other braking 5" from PE. I suggest settling for the 4" with a different build and break system (which I have not tried) or a different manufacturer.
Date published: 2011-01-26
Customer projects that include: 5" Braked Swivel Caster 250 Lb. Capacity
