299-967_ALT_0
299-967_ALT_1
5-1/4" Treated Paper Cone Shielded Woofer
Brand:|Part # 299-967
Repair or build your own bookshelf, satellite, center channel or computer speakers using this 5-1/4" shielded woofer and save over 68% off the original retail price. Quantities are extremely limited on this Parts Express exclusive buyout!
Part # 299-967
  • Foam surround with treated paper cone for a warm, natural sound
  • Shielded motor protects sensitive electronics
  • High Qts allows for open back dipole use
Frequently Bought Together
This 5-1/4" shielded woofer with foam surround was designed for use in home theater speakers, and is great for use in sealed, compact enclosures as bookshelf, center channel, and satellite speakers. The shielded motor also makes this woofer a great candidate for computer speakers that are placed closely to sensitive electronics.
Alternatively, you can repurpose this woofer as a midrange/midbass speaker in larger 3-way cabinets. Save over 68% off the original retail price through this Parts Express exclusive buyout. Quantities are extremely limited, act fast!
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)25 Watts
  • Power Handling (max)50 Watts
  • Impedance8 ohms
  • Frequency Response100 to 6,000 Hz
  • Sensitivity85 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)92 Hz
  • DC Resistance (Re)6.88 ohms
  • Voice Coil Inductance (Le)0.73 mH
  • Mechanical Q (Qms)3.72
  • Electromagnetic Q (Qes)1.56
  • Total Q (Qts)1.1
  • Compliance Equivalent Volume (Vas)0.15 ft.³
  • Maximum Linear Excursion (Xmax)1.5 mm
  • Cone MaterialTreated Paper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.75"
  • Baffle Cutout Diameter4.5"
  • Depth2.625"
  • Bolt Circle Diameter5.25"
  • # Mounting Holes4
  • Sealed Volume0.29 ft.³
  • Sealed F384 Hz
  • Vented Volume1.11 ft.³
  • Vented F351 Hz
  • BrandFactory Buyouts
  • Part Number299-967
  • UPC848864006314
  • Product CategoryProducts
  • Weight1.4 lbs.
View similar products to the 5-1/4" Treated Paper Cone Shielded Woofer
in the Products product category.
