320-3143_ALT_0
48 VDC 7.3A 350W Regulated Switching Power Supply
Brand:| Model: PS-SP11132
This 48 volt DC, 7.3 amp regulated power supply is capable of up to 350 watts of output. Switchable 90-264 volts AC input. UL recognized design.
  • Adjustable 41 to 56 VDC regulated output with 7.3A current capacity
  • Overload, over voltage, and over temperature protection built-in
  • Great for electronics projects, especially amplifiers
  • For use with electronics that demand up to 350 watts of power
320-3143
Weight: 2.28 lbs.
IN STOCK
List Price$77.99
You Save23%
$59.50
Buy 4-up$56.25
Part # 320-3143
This beast of a power supply is ideally suited for use with amplifier projects. With a regulated output of 48 volts DC, and current capacity of 7.3 amps, this power supply is the perfect partner for amplifiers with of up to 350 watts of output on tap.
Voltage input can be switched for use with 110 or 240 VAC mains power. Overload, over voltage, and over temperature protection is built-in, shutting down the power supply to prevent damage and then restoring power upon recovery. Power cable included. UL recognized design. Output voltage is adjustable from 41 to 56 VDC.
Note: Minimum recommend power wire gauge is 16 AWG.
Specifications: • Input power: Switchable between 90-132 VAC and 180-264 VAC, 47-63 Hz • Output power: 48 V, 7.3A • Dimensions: 8.66" L x 4.72" W x 2.36" H.
  • BrandParts Express
  • ModelPS-SP11132
  • Part Number320-3143
  • UPC848864002811
  • Product CategoryPower Supplies
  • Weight2.28 lbs.
View similar products to the 48 VDC 7.3A 350W Regulated Switching Power Supply
in the Power Supplies product category.
Customer projects that include: 48 VDC 7.3A 350W Regulated Switching Power Supply
