470uF 35V High Temp Radial Capacitor
Brand:|Part # 020-1748
High temperature electrolytics for use in switch mode power supplies found in TVs, VCRs, etc. 105° C operating temperature satisfies characteristic W of JIS-C-5141 standards. ± 20% tolerance.
$0.39
Buy 10-99 $0.29
Buy 100+$0.19
Part # 020-1748
  • Standard aluminum electrolytic capacitor series for general purpose
  • -40°C ~ +105°C temperature range
  • RoHS Compliance
Specifications: • Dimensions: 10 x 20 mm.
Note: Xicon is phasing out their line of electrolytic capacitors; therefore, we are transitioning to the Lelon brand. Rest assured that whatever brand you receive, your Xicon or Lelon capacitor will have comparable dimensions, equivalent specifications, and RoHS compliance.
  • Capacitance470 µF
  • Voltage Rating35V
  • Tolerance20%
  • Termination StyleRadial
  • BrandLelon
  • Part Number020-1748
  • UPC844632050534
  • Product CategoryElectrolytic Capacitors
    (4 Reviews)
  • Weight0.0066 lbs.
View similar products to the 470uF 35V High Temp Radial Capacitor
in the Electrolytic Capacitors product category.
470uF 35V High Temp Radial Capacitor is rated 5.0 out of 5 by 4.
Rated 5 out of 5 by from Great product with great service and priceI bought this product to replace burned ones with a lower voltage. It came in within a few few business days. I replace the burned out ones and now the Apex Digital Converter works like a charm. Spending 39 cent a piece saved me from buying a new digital TV. Great place to shop - quick service and great price!
Date published: 2014-03-03
Rated 5 out of 5 by from Just what a 23" LCD PS needsA 23" widescreen LCD display goes out, and this simple fix was all I needed. 6x50c caps and it has a new lease on life. Went for the 25v instead of the 16, so these will last longer! They were a little larger than the 16v i replaced, but there was snug room. You can always put heat shrink tubing on the leads and stand them up higher, or lean them over.
Date published: 2013-02-20
Rated 5 out of 5 by from Very SatisfiedAfter much local searching I found Parts Express online.I easily found what I was looking for at an exeptional price.These caps not only had my 42" lcd up and going again in no time, But the customer service was Excellent as was the Super fast shipping>>>>>>>>>I will definately be using Parts Express for my future electronic needs.
Date published: 2012-12-17
Rated 5 out of 5 by from great product...I believe these are the best capacitors around..
Date published: 2009-02-13
  • 2016-02-12T06:57CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_020-1748, PRD, sort_mostRecent
What is the substitute / alternative for this Capacitors 470 uf, 35 V, 105 deg C? It is always damaged.
Asked by: Emman
This cap is the only option we have that will work as a substitute. You might want to consider bumping up the voltage of the cap, assuming there is enough room for it.
Date published: 2014-09-18
  • 2016-02-12T07:15CST
  • loc_en_US, sid_020-1748, PRD, sort_recentQuestionsFirst
