47 Ohm 5W Resistor Wire Wound 5% Tolerance
Brand:|Part # 015-47
47 ohm 5 watt wirewound resistor with 5% tolerance. Sold individually.
$0.68
Buy 10-49 $0.48
Buy 50+$0.29
Part # 015-47
  • Exceptionally small, sturdy, and reliable
  • Ceramic flame retardant package
  • Sealed with a special quartz mixed sand cement
  • Excellent moisture resistance
  • High temperature stability
  • 5% tolerance
  • Temperature Range: -55°C ~ +155°C
47 ohm 5 watt wirewound resistor. Through-hole termination with axial leads. 5% tolerance. RoHS compliant. Dimensions (mm): Case: 22 L x 10 W x 9 H (±1); Lead length: 35 (±5). Sold individually.
  • Resistance47 ohms
  • CompositionWirewound
  • Power Rating5 Watt
  • Tolerance5%
  • BrandXicon
  • Part Number015-47
  • UPC844632034923
  • Product CategoryWire-wound Resistors
    (1 Reviews)
  • Weight0.0132 lbs.
View similar products to the 47 Ohm 5W Resistor Wire Wound 5% Tolerance
in the Wire-wound Resistors product category.
47 Ohm 5W Resistor Wire Wound 5% Tolerance is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from very nice under 130 watts inputBut above 130 watts in a x-over they have a tendance to color the sonic accuracey , I switched to the dayton 8 ohm 10 watt non inductive and the problem ended. You get what you pay for in other word's.
Date published: 2007-12-13
  • 2016-02-14T07:20CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_015-47, PRD, sort_mostRecent
is this resistor has zero inductance
Asked by: nidhi6
Our program will only measure inductance as low as 0.05 mH and this resistor does not register. This would be considered a low or non inductive resistor.
Date published: 2014-09-23
  • 2016-02-14T08:22CST
  • loc_en_US, sid_015-47, PRD, sort_recentQuestionsFirst
