44-Key LED Control Unit with IR Remote Control
Brand:| Model: LE-LL19112
Designing your custom lighting solution is made easy with this 44-key LED control unit. An IR remote control is included for remote operation.
  • Great for product displays or window treatments
  • Drives up to 5 meters of 12 VDC RGB LED strips
  • IR remote control included
  • 6 memory locations
073-004
Weight: 0.15 lbs.
IN STOCK
List Price$14.99
You Save33%
$9.97
Buy 4-up$9.47
Part # 073-004
Create custom lighting effects with this 44-key IR remote control and LED control unit, that's specifically designed to work with 12 VDC RGB LED light strips. Adjust brightness, color, fade in/out, and flash rate. Supports up to five meters of RGB LED light strips. Other tri-color, common anode LEDs may be used if configured to work with 12 VDC supply voltage by the use of voltage dropping resistors. IR remote control uses a CR2025 battery (included). Requires 12 VDC power supply (not included).
Specifications: • Power requirements: 12 VDC, 2A (minimum recommended), 12 VDC, 6A (with max current draw from each of three LEDs) • Power input: 2.1 x 5.5 mm, center positive • Output: Three CMOS drain-open output • Connection type: Common anode • Control unit dimensions: 63 mm (2.48") L x 35 mm (1.38") W x 22 mm (0.87") H.
Note: To use the DIY memory keys, press the desired memory key, use the up/down red, green, or blue arrows to adjust to desired color, then press the DIY memory key again to store the color. Due to the IR operation of this product, it is possible for remote controls of other devices to inadvertently change LED settings.
Remote control button layout
Brightness + (7 steps)Brightness - (7 steps)Pause/RunOn/Off
Static redStatic greenStatic blueStatic white
Static orangeStatic pea greenStatic dark blueStatic off-white
Static dark yellowStatic cyanStatic royal blueStatic light pink
Static yellowStatic light blueStatic pinkStatic green white
Static light yellowStatic sky blueStatic brownStatic blue white
Increase redIncrease greenIncrease blueSpeed up
Decrease redDecrease greenDecrease blueSpeed down
Memory 1Memory 2Memory 3Automatic change
Memory 4Memory 5Memory 6Flash on and off
3 color change7 color change3 color fade change7 color fade change
  • BrandParts Express
  • ModelLE-LL19112
  • Part Number073-004
  • UPC844632093364
  • Product CategoryAccent & Party Lighting
    (5 Reviews)
  • Weight0.15 lbs.
View similar products to the 44-Key LED Control Unit with IR Remote Control
in the Accent & Party Lighting product category.
44-Key LED Control Unit with IR Remote Control is rated 4.8 out of 5 by 5.
Rated 5 out of 5 by from Great for the priceWorks as advertised. Instructions a little weak but what do you expect for the price
Date published: 2014-11-23
Rated 5 out of 5 by from Really nice addition to home automation system.I bought this as part of the bundle with the 5 meter RGB strip.I mounted parts of the strip under both sides of my front outside stairs.I extended the wiring to my garage where the controllers connects to the strips.My automation system is controlled by HomeSeer in my office which learned the 44 key remote's commands. I extended my IR blaster's output to the garage where I coupled the blaster's IR emitter to the unit's IR input. This is just a simple cable run.I added a Web interface to control the LEDs manually and created some events which make the LEDs light in certain ways depending upon preprogrammed events.I'm expanding the strips to other locations on the property.Great Stuff.Thanks Parts Express!
Date published: 2014-07-07
Rated 5 out of 5 by from Great controllerGreat Controller with many different color presets and effects. I bought this 44 button controller because I bought at the same time, the 5m strip leds and part of this package was the basic controller with no user creatable presets. Also, the basic does not allow you to dial in the color. Both of these things, in my opinion are pretty important. I'm just a lighting guy after all :) So, that being said, this controller definately gives the user all the control over the leds they could want and from a pretty good distance with the remote.The only thing I would remind anyone who is considering purchasing this is that you do need to have a 12V DC 2.5mmX 5.5mm plug power source for this. This is not provided in the box.
Date published: 2013-09-23
Rated 4 out of 5 by from Good Mixer, No SequencingIt's important to keep in mind that this thing is incredibly inexpensive. It has excellent RGB color mixing capabilities and 6 custom color memory buttons. It has a play/pause button, which gives you the false impression of sequencing capabilities, but the only sequences available are simple preset color rotations. Nonetheless, you can slow down these preset sequences, the fades are very smooth and quite impressive. I'd love to be able to set my own simple color fades. In the end, this is a great static color mixer.
Date published: 2012-02-23
Rated 5 out of 5 by from Great ProductThe LED light strip was used on my entertainment center, underneath the shelves where it can't be seen, and around the edge. Looks fantastic, you'd think it was there from the factory. Adds nice lighting to that corner of the room.Remote has lots of effects, but I most often use the various color controls, and the brightness buttons. Will probably use the lighting effects (flash, fade, etc) for parties, Christmas and other events.Remote works great from the other side of the room. I hung the sensor down just a bit where it wasn't completely blocked, but it still can't be seen yet works nicely.
Date published: 2011-11-21
  • 2015-04-28T09:38CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_073-004, PRD, sort_mostRecent
When I plug two or three sets together I lose some lights in second string and dim in third string.  Is there a solution for that?  Thanks.
Asked by: RedProwler
Only one RF controller is recommended. you can however, add additional units with the high power version #073-005
Answered by: TomI
Date published: 2015-04-13
Hello! Works fine, but I need the complete manual for controller with 44-key IR. Do you have a download-link?
Asked by: Guenni
All information available is under the "Product Details" section. #073-004http://www.parts-express.com/44-key-led-control-unit-with-ir-remote-control--073-004
Answered by: TomI
Date published: 2015-02-11
Static white shows all colours; what am I doing wrong?
Asked by: Budds
White is compromised of the three primary colors. Red green and Blue.
Answered by: TomI
Date published: 2015-01-20
I purchase this but when I try to power off the light it does not shut off all the way it stays lit at a dim blue? All other colors turn off but the blue light?
Asked by: 98Joed
You may have a bad controller or connection problem. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-01-05
High, I bought an LED strip with one of these controllers, but the pause/run button and the whole DIY section does not work, only white. Should I buy a new controller?
Asked by: Xephyr
Date published: 2014-12-31
On my 44 key remote, the blue button controls the green lights and the green lights control the blue lights.  Does anyone know how to reprogram the remote?
Asked by: WillieG
The 24 key reprogram instructions work for both remote options, but for the 44 key remote you will want to use the JUMP3 button instead of SMOOTH. Everything else is the same.www.parts-express.com/pedocs/manuals/reprogramming-an-led-controller-manual.pdf
Date published: 2014-11-10
  • 2015-04-28T12:08CST
  • co_hasquestionsanswers, tq_25
  • loc_en_US, sid_073-004, PRD, sort_recentQuestionsFirst
Customer projects that include: 44-Key LED Control Unit with IR Remote Control
