Clearance Item
073-066_ALT_0
073-066_ALT_1
073-066_ALT_2
073-066_ALT_3
4 x 1W RGBY Quadcolor LED with Driver Board and Interface
Brand:| Model: LE-LL21113
This RGBY quadcolor LED board features a built-in DC-DC power converter and the ability to connect up to six additional boards. On-board DIP switches control each LED, or connect the RGBY audio sync board to create amazing effects in time to your music.
  • High quality Golden Dragon LEDs made by Osram
  • Designed to connect directly to the RGBY audio sync controller
  • Daisy chain up to six RGBY quadcolor boards
  • Integrated DC-DC controller built-in for using 9 to 25 VDC power supplies
  • Able to be controlled externally with pulse width modulation
  • External interface for connecting up to three additional LEDs
073-066
Weight: 0.25 lbs.
Create the ultimate light show with quadcolor LED boards. The driver board is built onto the same circuit board as the RGBY LEDs for a compact solution that can be mounted nearly anywhere. 8-pin input and output connectors (mounted on the bottom of the board) offer quick connection to the RGBY audio sync controller or RGBY tester board for control, and for connecting up to six additional quadcolor RGBY LED boards (one 8-pin cable included). Four dip switches on the circuit board offer color control (see manual in the Manuals/Resources section on the right for more information). Additionally, each LED on the board can be controlled with pulse width modulation (see manual for more information). An external interface has been added for connecting up to three additional external LEDs.
Board Specifications: • Power requirement: 9 to 25 VDC (19 VDC, 2.1A power supply recommended) • Power input jack: 2.1 mm ID x 5.5 mm OD • Dimensions: 3" W x 3" L x 0.72" H (76.2 x 76.2 x 18.4 mm).
LED Specifications (nominal): Red: 625 nm wavelength, 45 lumens • Green: 530 nm wavelength, 75 lumens • Blue: 470 nm wavelength, 23 lumens • Yellow: 590 nm wavelength, 43 lumens.
  • BrandParts Express
  • ModelLE-LL21113
  • Part Number073-066
  • UPC844632093678
  • Product CategoryHigh-Power LED Assemblies
    (1 Reviews)
  • Weight0.25 lbs.
View similar products to the 4 x 1W RGBY Quadcolor LED with Driver Board and Interface
in the High-Power LED Assemblies product category.
4 x 1W RGBY Quadcolor LED with Driver Board and Interface is rated 2.0 out of 5 by 1.
Rated 2 out of 5 by from Not goodMy first purchase of (2) yielded (2) failures. Both had one out of four led's out. I did see that someone else had posted a similar review. I re-purchased another (2) and these did work.I have to admit Parts-Express has top notch customer service!
Date published: 2013-02-02
  • 2015-02-19T16:13CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_073-066, PRD, sort_mostRecent
Customer projects that include: 4 x 1W RGBY Quadcolor LED with Driver Board and Interface
