4" Swivel Caster 250 Lb. Capacity 3800 Series Plate
• 4" Swivel Caster • Overall height: 4-15/16" • Top plate: 2-1/2" x 3-5/8" • Bolt hole pattern: 1-3/4" x 2-7/8" slotted to 3" • Ball bearing
  • 250 lb. Carrying capacity
  • Case hardened double ball raceways provide extra capacity & durability
  • Gray polyurethane on beige polyolefin wheel does not mark floors
  • 1-1/4" wide wheel for excellent traction & stability
262-085
Weight: 1.8 lbs.
IN STOCK
$9.57
Buy 10-up$8.79
Part # 262-085
The 3800 series of low-cost casters are perfect for equipment racks, bass bins, movie and soundstage equipment, or storage containers for the weekend band to the professional touring musician. Other applications include light-duty material handling equipment, food service carts & equipment, bakery racks & equipment, miscellaneous dollies, mobile cases, displays, mobile wire racking, stock carts, textile applications, warehouse & manufacturing applications, etc. Sold individually. • 4" Swivel Caster • Overall height: 4-15/16" • Top plate: 2-1/2" x 3-5/8" • Bolt hole pattern: 1-3/4" x 2-7/8" slotted to 3" • Ball bearing
  • Caster TypeSwivel
  • Wheel Diameter4"
  • Color / FinishZinc
  • BrandParts Express
  • Part Number262-085
  • UPC844632034626
  • Product CategoryCasters
    (2 Reviews)
  • Weight1.8 lbs.
View similar products to the 4" Swivel Caster 250 Lb. Capacity
in the Casters product category.
4" Swivel Caster 250 Lb. Capacity is rated 4.0 out of 5 by 2.
Rated 5 out of 5 by from smooth rideI bought these to replace a set of "cheepie" wheels I put on a JBL JRX subwoofer that I use professionally. These 4" wheels not only get over sidewalk cracks and doorway moldings much easier the relative soft rubber of the wheels make for a smooth ride. It makes moving around so much easier and I'm less concerned about vibrating the power amp in the sub. The old hard plastic wheels caused the amp screws to vibrate loose. Just take care in where you mount the wheel in a recessed fitting to ensure there is clearance for 360 movement of the swivel wheel.
Date published: 2013-01-27
Rated 3 out of 5 by from Standard qualityStandard caster that will be used for an amp rack that's new so opinion is limited.
Date published: 2007-09-25
Customer projects that include: 4" Swivel Caster 250 Lb. Capacity
