4" Shielded Paper Cone Woofer 8 Ohm
Brand:|Part # 299-974
Repair or build your own bookshelf, satellite, center channel or computer speakers using this 4" shielded woofer and save over 50% off the original retail price. Quantities are extremely limited on this Parts Express exclusive buyout!
Part # 299-974
  • Pincushion frame for close center-to-center spacing
  • Shielded design for close placement to sensitive electronics
  • Works well in small sealed enclosures
Frequently Bought Together
This 4" shielded woofer with foam surround was designed for use in home theater speakers, and is great for use in sealed, compact enclosures as bookshelf, center channel, and satellite speakers. The shielded motor also makes this woofer a great candidate for computer speakers that are placed closely to sensitive electronics.
Alternatively, you can repurpose this woofer as a midrange/midbass speaker in larger 3-way cabinets. Save over 50% off the original retail price through this Parts Express exclusive buyout. Quantities are extremely limited, act fast!
  • Nominal Diameter4"
  • Power Handling (RMS)25 Watts
  • Power Handling (max)50 Watts
  • Impedance8 ohms
  • Frequency Response80 to 6,000 Hz
  • Sensitivity85 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)73 Hz
  • DC Resistance (Re)6.8 ohms
  • Voice Coil Inductance (Le)0.79 mH
  • Mechanical Q (Qms)2.8
  • Electromagnetic Q (Qes)1.16
  • Total Q (Qts)0.82
  • Compliance Equivalent Volume (Vas)0.2 ft.³
  • Maximum Linear Excursion (Xmax)2 mm
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5" diagonally, edge to edge is 4.375"
  • Baffle Cutout Diameter4.125"
  • Depth2.5"
  • Bolt Circle Diameter4.75"
  • # Mounting Holes4
  • BrandFactory Buyouts
  • Part Number299-974
  • UPC848864006420
  • Product CategoryProducts
  • Weight1.75 lbs.
View similar products to the 4" Shielded Paper Cone Woofer 8 Ohm
in the Products product category.
