4" Shielded One Piece Poly Coated Paper Woofer 4 ohm
Brand:|Part # 299-978
Repair or build your own bookshelf, satellite, center channel or computer speakers using this 4" shielded, poly-coated, one-piece paper cone woofer and save over 60% off the original retail price. Quantities are extremely limited on this Parts Express exclusive buyout!
Part # 299-978
  • One-piece, poly-coated-paper cone
  • Designed for small sealed enclosures
  • Shielded design protects sensitive electronics
Frequently Bought Together
This shielded 4" poly-coated, one-piece paper cone woofer with foam surround was designed for use in home theater speakers, and is great for use in small sealed enclosures as bookshelf, center channel, and satellite speakers. The shielded motor also makes this woofer a great candidate for computer speakers that are placed closely to sensitive electronics.
The 4 ohm impedance extracts more current from amplifiers for an increase of 3 dB in output over an 8 ohm variant. Wire two in series for a safe 8 ohm load when used in MTM configurations. Alternatively, you can repurpose this woofer as a midrange/midbass speaker in larger 3-way cabinets or even as a car audio speaker. Save over 60% off the original retail price through this Parts Express exclusive buyout. Quantities are extremely limited, act fast!
  • Nominal Diameter4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance4 ohms
  • Frequency Response70 to 5,000 Hz
  • Sensitivity84 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)64 Hz
  • DC Resistance (Re)3.23 ohms
  • Voice Coil Inductance (Le)0.47 mH
  • Mechanical Q (Qms)4.25
  • Electromagnetic Q (Qes)0.71
  • Total Q (Qts)0.61
  • Compliance Equivalent Volume (Vas)0.17 ft.³
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Cone MaterialPoly Composite
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5"
  • Baffle Cutout Diameter4"
  • Depth2.5"
  • Bolt Circle Diameter4.625"
  • # Mounting Holes4
  • Sealed Volume0.22 ft.³
  • Sealed F384 Hz
  • Vented Volume0.4 ft.³
  • Vented F342 Hz
  • BrandFactory Buyouts
  • Part Number299-978
  • UPC848864006475
  • Product CategoryProducts
    (1 Reviews)
  • Weight1.8 lbs.
View similar products to the 4" Shielded One Piece Poly Coated Paper Woofer 4 ohm
in the Products product category.
