4" Paper Cone Midrange Speaker 8 Ohm
Brand:|Part # 289-133
Repair, upgrade, or build your own speakers today with this 4" paper cone midrange and save over 55% off the original retail price through this exclusive Parts Express buyout. Hurry, quantities are limited!
  • Sensitive speaker for vocal reproduction
  • Great for small public address applications
  • Wide 250 to 8,000 Hz frequency response
This 4" midrange driver is designed to be relatively sensitive in the 250 to 8,000 Hz band, for low power vocal reproduction applications. The treated paper surround and poly dust cap offer decent resistance against humidity, while the thin mount design allows for installation in many locations.
Save over 55% off the original retail price through this Parts Express exclusive factory buyout. Hurry, quantities are limited!
Note: This speaker features four 1/8" by 1/4" mounting slots, that may be notched using diagonal cutters to accommodate wood screws.
  • Nominal Diameter4"
  • Power Handling (RMS)4 Watts
  • Power Handling (max)8 Watts
  • Impedance8 ohms
  • Frequency Response250 to 8,000 Hz
  • Sensitivity91 dB 1W/1m
  • Voice Coil Diameter0.5"
  • Resonant Frequency (Fs)275 Hz
  • DC Resistance (Re)7.0 ohms
  • Voice Coil Inductance (Le)0.47 mH
  • Mechanical Q (Qms)8.94
  • Electromagnetic Q (Qes)3.43
  • Total Q (Qts)2.48
  • Compliance Equivalent Volume (Vas)0.03 ft.³
  • Maximum Linear Excursion (Xmax)1 mm
  • Cone MaterialPaper
  • Surround MaterialTreated Paper
  • Magnet MaterialFerrite
  • Overall Outside Diameter5" across mounting tabs, 4.125"
  • Baffle Cutout Diameter3.625"
  • Depth1.5"
  • Sealed Volume0.01 ft.³
  • Sealed F3305.8 Hz
  • Vented Volume1.08 ft.³
  • Vented F3133 Hz
  • BrandFactory Buyouts
  • Part Number289-133
  • UPC848864015132
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (1 Reviews)
  • Weight0.6000 lbs.
View similar products to the 4" Paper Cone Midrange Speaker 8 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
