3M 3/4" Black Heat Shrink Tubing 4 ft.
Brand:|Part # 082-058
3M™ heat shrink shrinks to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for 275ºF(135ºC) continuous operation.
$4.48
Buy 10-49 $3.90
Buy 50+$3.31
Part # 082-058
  • Shrinks to half its size
  • Usually used over electrical splices and terminations
  • Split and cold resistant
3M™ heat shrink shrinks to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for 275ºF(135ºC) continuous operation. This tubing is typically used as a shrink-fit electrical insulation over splices and terminations. It is also used for lightweight wire harness covering, wire marking, wire bundling, component packaging and fire resistant covering. The heat shrink tubing is split resistant, mechanically tough, easily marked and resists cold flow. Sold in 4 ft. lengths with header.
Specifications: • UL Recognized and CSA Certified at 600 volts at 257ºF(125ºC) • UL File No. E-39100 and CSA No. 38227. MIL-I-23053/5, Class 1,2. AMS 3636 (Type I) and AMS 3637 (Type II).
  • Nominal Preshrink I.D.3/4" (19 mm)
  • Shrink Ratio2-to-1 (2:1)
  • ColorBlack
  • Length4 ft.
  • Adhesive SealantNo
  • Brand3M
  • Part Number082-058
  • UPC051135368121
  • Product CategoryHeat Shrinkable Tubing
    (4 Reviews)
  • Weight0.0858 lbs.
View similar products to the 3M 3/4" Black Heat Shrink Tubing 4 ft.
in the Heat Shrinkable Tubing product category.
3M 3/4" Black Heat Shrink Tubing 4 ft. is rated 4.75 out of 5 by 4.
Rated 5 out of 5 by from Versatile Stuff!Didn't need this tubing for anything electrically related. Far from it. I bought this to use on the barrels of my breakbarrel air rifles. If you're familiar with the type of rifles I'm referring to, you get it. If not, trust me. At the end of a barrel (unshrouded) where you grab it to pull it down for cocking and loading, some wear & tear in the form of scuffing and surface rust can eventually occur. By 'insulating' the top 6 inches with shrink tubing, it protects the barrel from the afore mentioned unsightly damage, hence, eliminating the extra maintenance of removing surface rust, etc. The 2 barrels I did this to are removable from their breech pivots, so, no problem sliding the tubing on...in case anyone was wondering. lol (On another rifle (scoped) where the barrel is not removable, I'm contemplating removing the unused forward sight to shrink the 'grab zone'....jury's still out.)(I've also used a LOT of heatshrink for electrical purposes...I'm sure this would work just fine for that, as well!)
Date published: 2015-06-09
Rated 5 out of 5 by from Great productI used the heat shrink to cover a metal strap I am using to secure a battery on a portable tailgate boom box. It works great! I had no issues shrinking it with my heat gun.
Date published: 2014-08-11
Rated 4 out of 5 by from Good stuff3M. Enough said.
Date published: 2009-01-27
Rated 5 out of 5 by from High qualityMuch heavier & stronger than most other readily available brands. Also has a smoother surface & remains very flexible. It takes a little longer to shrink, but the higher quality is well worth the extra time.
Date published: 2008-10-11
  • 2016-02-10T07:14CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_082-058, PRD, sort_mostRecent
Videos
