3M 1/2" Red Heat Shrink Tubing 4 ft.
Brand:
3M™ heat shrink shrinks to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for 275ºF(135ºC) continuous operation.
$3.87
Buy 10-49 $3.20
Buy 50+$2.66
Part # 082-052
  • Shrinks to half its size
  • Usually used over electrical splices and terminations
  • Split and cold resistant
3M™ heat shrink shrinks to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for 275ºF(135ºC) continuous operation. This tubing is typically used as a shrink-fit electrical insulation over splices and terminations. It is also used for lightweight wire harness covering, wire marking, wire bundling, component packaging and fire resistant covering. The heat shrink tubing is split resistant, mechanically tough, easily marked and resists cold flow. Sold in 4 ft. lengths with header.
Specifications: • UL Recognized and CSA Certified at 600 volts at 257ºF(125ºC) • UL File No. E-39100 and CSA No. 38227. MIL-I-23053/5, Class 1,2. AMS 3636 (Type I) and AMS 3637 (Type II).
  • Nominal Preshrink I.D.1/2" (12 mm)
  • Shrink Ratio2-to-1 (2:1)
  • ColorRed
  • Length4 ft.
  • Adhesive SealantNo
  • Brand3M
  • Part Number082-052
  • UPC051128596715
  • Product CategoryHeat Shrinkable Tubing
    (5 Reviews)
  • Weight0.0396 lbs.
View similar products to the 3M 1/2" Red Heat Shrink Tubing 4 ft.
in the Heat Shrinkable Tubing product category.
3M 1/2" Red Heat Shrink Tubing 4 ft. is rated 4.4 out of 5 by 5.
Rated 5 out of 5 by from Works greatPerfect for my diy cables and interconnects. Use it all the time.
Date published: 2014-09-11
Rated 5 out of 5 by from Solved my problemGoodf service
Date published: 2008-08-11
Rated 2 out of 5 by from Works as advertisedColor is more pink than red.
Date published: 2008-08-10
Rated 5 out of 5 by from PINK NOT REDPE sells 3M which is better then other generics. Beware of the RED however, as it is really more of a PINK color, before and after shrinking.
Date published: 2008-01-21
Rated 5 out of 5 by from Parameters exactly as advertisedVeryVery convenient to work with, flexible in sizes,good variety of colors.
Date published: 2007-11-12
  • 2015-08-04T07:52CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_082-052, PRD, sort_mostRecent
Videos
