3M 1/2" Black Heat Shrink Tubing 4 ft.
Brand:|Part # 082-046
3M™ heat shrink shrinks to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for 275ºF(135ºC) continuous operation.
$3.87
Buy 10-49 $3.20
Buy 50+$2.66
Part # 082-046
  • Shrinks to half its size
  • Usually used over electrical splices and terminations
  • Split and cold resistant
3M™ heat shrink shrinks to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for 275ºF(135ºC) continuous operation. This tubing is typically used as a shrink-fit electrical insulation over splices and terminations. It is also used for lightweight wire harness covering, wire marking, wire bundling, component packaging and fire resistant covering. The heat shrink tubing is split resistant, mechanically tough, easily marked and resists cold flow. Sold in 4 ft. lengths with header.
Specifications: • UL Recognized and CSA Certified at 600 volts at 257ºF(125ºC) • UL File No. E-39100 and CSA No. 38227. MIL-I-23053/5, Class 1,2. AMS 3636 (Type I) and AMS 3637 (Type II).
  • Nominal Preshrink I.D.1/2" (12 mm)
  • Shrink Ratio2-to-1 (2:1)
  • ColorBlack
  • Length4 ft.
  • Adhesive SealantNo
  • Brand3M
  • Part Number082-046
  • UPC051128596685
  • Product CategoryHeat Shrinkable Tubing
    (5 Reviews)
  • Weight0.0396 lbs.
View similar products to the 3M 1/2" Black Heat Shrink Tubing 4 ft.
in the Heat Shrinkable Tubing product category.
3M 1/2" Black Heat Shrink Tubing 4 ft. is rated 5.0 out of 5 by 5.
Rated 5 out of 5 by from Perfect for Mogami 2524 and 2792 CableWorked perfectly for these cable builds, great value.
Date published: 2013-09-19
Rated 5 out of 5 by from Great StuffShrinks up better, thicker and a lot cheaper than what you can get at those big chain stores I don't want to mention, and I mean a "LOT" cheaper. Thanks P.E.
Date published: 2013-01-09
Rated 5 out of 5 by from 3M What else can you say!The best heat shrink we have found, and at a good price point.
Date published: 2009-05-16
Rated 5 out of 5 by from Heat shrinkWell it does what it's supposed to and holds up well over time. That's all I can ask for.
Date published: 2008-03-04
Rated 5 out of 5 by from excellent checked all colors boughtEXCELLENT: USED CALIPERS TO checked dia. after shrinkage ALL COLORS OF PURCHASED OF RED,GREEN,BLUE,WHITE AND YELLOW OF .375 (3/8) DIA.(colors .375 DIA.) After shrinkage the dia. of the heat shrink tubing was ranged from .175 to .187 diameter all lengths tested were approximate 1/2 inch in long.(BLACK) The .500 dia. after shrinkage was approxmately = OR < .250 inch. All SHRANK DURING THE HEATING WAS EXCELLENT TYPE OF HEAT APPLIED. The barrel of the soldering iron was used. Do not use the tip of the Iron This will distroy the SOLDER tinning of the tip.Another way to heat the tubing in close places is to purchase a very cheap iron and use the tip for heat shrink only. This iron will not be used for soldering.
Date published: 2007-11-06
  • 2016-02-09T06:50CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_082-046, PRD, sort_mostRecent
I'm new to heatshrink. Is the 1/2" the original or ending size?
Asked by: destrecht
The size listed for heat shrink is the pre-shrink diameter.
Date published: 2014-06-16
In saying that this 1/2" heat shrink is 2:1, does it start at 1/2" and shrink to 1/4"? or does it start at 1" and shrink to 1/2"?
Asked by: Shmuel
Begins at 1/2" and ends at 1/4"
Answered by: markajh
Date published: 2012-07-05
  • 2016-02-09T07:15CST
  • loc_en_US, sid_082-046, PRD, sort_recentQuestionsFirst
Videos
