120-840_ALT_0
3A Variac Variable AC Power Transformer 0-130 VAC
Brand:| Model: 3A Variac 0~130
An essential component of any test bench, a variac autotransformer allows the user to adjust incoming 110/120 VAC to 0~130 VAC via a dial.
  • Easy operation by the knob on top of the unit
  • Meter makes it easy to see output voltage
  • Tabletop unit has 3A current capacity
120-840
Weight: 6.5 lbs.
IN STOCK
$55.75
Part # 120-840
A variac is an extremely handy device that allows the user to dial 110/120 VAC wall voltage up or down from 0~130 VAC, measured by a meter on the front of the unit.
Most often, variacs are used on test benches, either to troubleshoot problems, test experimental circuits, or slowly power up vintage electronics to evaluate and perhaps recondition aging internal components.
They're also used in performing arts and cinematography to control lighting. In areas where line voltage runs higher than standard, use of a variac can improve the function and longevity of electronics.
Current capacity: 3A.
  • BrandParts Express
  • Model3A Variac 0~130
  • Part Number120-840
  • UPC848864002750
  • Product CategoryVariac Variable Transformers
    (2 Reviews)
  • Weight6.5 lbs.
View similar products to the 3A Variac Variable AC Power Transformer 0-130 VAC
in the Variac Variable Transformers product category.
3A Variac Variable AC Power Transformer 0-130 VAC is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from 3A Variac AC Power SupplyThis item is better than I expected. Arrived quickly, packaged securley and works like a charm. The meter is very accurate and the variac does not hum. Just what I needed at the best price around. Thank you Parts Express.
Date published: 2014-09-14
Rated 5 out of 5 by from Optimum unit for hot wire cutting EPS foam.I have used this item on virtually all of the stylus pattern EPS foam cutters, of which I am the original designer, and have sold for more than 20 years. It is absolutely the smartest way to power a foam cutter. The voltage adjustment is infinite from 0 to 130 volts. You typically need only about half the output to power a 60-inch, .014: inconel .wire, which is the ONLY wire to use when cutting EPS foam. It is the strongest, quickest to heat up, and with the least amount of stretch.This power supply comes ready to use. Simply alter a two-wire extension cord (eliminate the green ground if using 3-wire type) and attach the black and white wires to each end of the cutting wire. First make sure the unit is turned to zero. Plug the variable transformer into any 120-volt AC outlet and then plug the altered extension cord into the outlet on the front of the unit. Place a piece of EPS foam on top of the cutting wire which must be elevated so the foam piece will drop down when you turn up the voltage. I have found that the optimum heat is obtained when smoke rises from the cutting wire almost immediately after it has passed through the foam. This is the styrene residue burning off the wire. By keeping the wire elevated, and slowly increasing the voltage, you then pass a test piece of scrap EPS foam across the inconel wire allowing you to obtain the optimum heat. Good luck.
Date published: 2014-08-08
Can I use this “3A Variac Variable AC Power Transformer 0-130 VAC” for testing 5KVA automatic voltage stabilizer without load?
Asked by: avik
can this be used with a heating mantle rated at 350 Watts, 110 volts. I'd be using the variac mainly to decrease the volts and the heat generated.
Asked by: cocoleka
Well, at 3amp--110volts, you are right at the line. I suggest a higher amp unit for safety. I'm not saying that this won't work, but experience tells me that anything to do with 110/120 volts,[or higher] a safety margin of 10 to 20% insures not just safety, but long useful life of the unit. See suggestions below.
Answered by: Joe from San Francisco
Date published: 2013-10-22
Customer projects that include: 3A Variac Variable AC Power Transformer 0-130 VAC
