090-294_ALT_0
3.5mm Stereo Plug To Dual RCA Jack Adapter
3.5mm stereo plug to dual RCA jack adaptor.
090-294
Weight: 0.025 lbs.
IN STOCK
List Price$4.99
You Save68%
$1.56
Buy 10-99 $1.25
Buy 100-up$1.17
Part # 090-294
  • BrandParts Express
  • Part Number090-294
  • UPC844632014086
  • Product Category3.5 mm Mini Adapters
    (14 Reviews)
  • Weight0.025 lbs.
View similar products to the 3.5mm Stereo Plug To Dual RCA Jack Adapter
in the 3.5 mm Mini Adapters product category.
3.5mm Stereo Plug To Dual RCA Jack Adapter is rated 4.5 out of 5 by 14.
Rated 1 out of 5 by from Poorly manufactured product.This adapter didn't work right out of the box & it makes a rattling sound when handled or shaken. I verified that every other piece of equipment in the signal path works.I just received the replacement sent by P.E. customer service. This time, I tried another brand of RCA cable that I own instead of the one purchased from P.E. along with this adapter. The cable from P.E. seems to have slightly over-sized center conductors on the RCA connectors, so I thought maybe this contributed to the malfunction of the item. The replacement worked for a few minutes. However, after trying a couple different RCA cables, is now also broken. It rattles and delivers audio only through the right side just like the first one. I dis-assembled both units to find that the left channel center barrel conductor is broken where it is bent to make connection to the T.R.S. jack.I, for one, wont be purchasing anything else from P.E. whose country of origin is not stated in the item description. I recommend buying a y-cable adapter from one of the U.S. companies who manufacture their own assemblies. It doesn't take much effort to find them and even though the cost is significantly higher, your not paying money for the privilege of disposing of someone's garbage.
Date published: 2013-08-13
Rated 5 out of 5 by from Great little adapterI own quite a few of these adapters. I use them to connect my headphones to seveal different components that have RCA audio out jacks. I also use them for computer speaker connection and game system audio connection. These adapters make tight secure stereo connections. They are built well and last forever. I have a couple that I have been using for more than 5 years. They are not audiophile grade by any means, but for a good solid RCA to 3.5mm stereo connection they work great. Couple these with various patch cables, and connectors and you can have stereo sound almost anywhere. The patch cables, adapter cables and connector that I use regularly are listed in my recommendations.
Date published: 2012-07-01
Rated 3 out of 5 by from could break the phone jack internallyOne problem with solid adapters like this is the leverage of the added length of the adapter and the weight of the connectors and cables could break the phone jack internally. It might be better if there was a length of flexible wire between the phone plug and the rca jacks. A right angle adapter might not work in the space availble on the device with the phone jack.
Date published: 2011-04-29
Rated 5 out of 5 by from Great for Game System to Computer SpeakersThis little adapter attached to a 3.5mm coupler (090-318) is perfect for taking a Wii outside and hooking the audio up to a set of computer speakers. Add a LCD projector, and Tiger Woods 2010 is lifesize! Super inexpensive for the convenience of the application.
Date published: 2012-05-29
Rated 5 out of 5 by from Works great.Arrived in good condition.
Date published: 2011-02-17
Rated 5 out of 5 by from GOOD PRICE & FAST SHIPPINGI DON'T SHOP AROUND ANY MORE. PARTS EXPRESS IS THE GO TO STORE.
Customer projects that include: 3.5mm Stereo Plug To Dual RCA Jack Adapter
