3.5mm Stereo In-line Jack
3.5mm stereo in-line jack.
090-289
Weight: 0.0264 lbs.
OUT OF STOCK
Due In: 1/6/2015
$1.39
Buy 10-99 $1.29
Buy 100-up$1.09
Part # 090-289
  • GenderFemale / Jack
  • Mounting TypeCable Mount
  • ConductorsStereo (TRS)
  • BrandParts Express
  • Part Number090-289
  • UPC844632033711
  • Product Category3.5 mm Mini Connectors
    (8 Reviews)
  • Weight0.0264 lbs.
View similar products to the 3.5mm Stereo In-line Jack
in the 3.5 mm Mini Connectors product category.
3.5mm Stereo In-line Jack is rated 3.25 out of 5 by 8.
Rated 1 out of 5 by from Ok for very, very light use.Really low quality connector. Mating plugs do not fit very tightly after the first few plugs and unplugs. every few uses i have to go in with a tiny screwdriver and bend the contacts back so they actually keep working.if you're only going to connect and disconnect a few times, they will work.As others mentioned, it's difficult to solder without melting the plastic backing (which makes the above contact problem even worse by loosening the contacts)of the 6 i ordered, about 3 had threads with a nasty burr on them, and need cleanup with a tiny triangular file before i could even screw the housing onto the connector base.I wish the Parts Express team had a better-quality option available. This is a common connector size. they have multiple options available in other connector sizes, why not this one?
Date published: 2012-11-06
Rated 3 out of 5 by from You Deserve BetterJust barely OK. Since you're investing your time soldering it is almost surely worth spending another buck or two for a better quality item. Too bad Parts Express is not currently carrying one. I had to go elsewhere to replace this. Positives: it is very light weight and the molded plastic housing and strain relief look nice enough. Negatives: Cheap feel. The threads are rough. The action is stiff. Seems like it will not hold up to much use. As another reviewer noted, you have to be careful not to overheat when soldering as the internal plastic that holds the contacts melts easily.
Date published: 2011-01-28
Rated 5 out of 5 by from BEST FOR PRICE!!!!!I was Very Pleased+++++Thank You
Date published: 2008-08-06
Rated 4 out of 5 by from what you get is what you pay fornot good quality stuff, the plastic threading on the inside already stripped for mine, but it's fun to play around with. don't buy these for something you're gonna unplug a lot.
Date published: 2008-03-27
Rated 4 out of 5 by from Great for just getting started.These baby's work good for hobbyist and everyday use operations. But don't expect real high quality. Good for the price. Will probably buy again.
Date published: 2008-03-15
Rated 1 out of 5 by from Use caution when solderingUse a low-wattage soldering iron and don't linger when soldering the connections -- The plastic housing the contacts melts easily and makes the jack inoperable.Definitely not up to the usual Parts Express quality standards.
Date published: 2008-03-06
Customer projects that include: 3.5mm Stereo In-line Jack
Customers Also Bought
3.5mm Mono In-line Jack
Part # 090-295
3.5mm Stereo Plug
Part # 090-292
