090-296_ALT_0
3.5mm Mono Chassis Jack
3.5mm mono chassis jack.
090-296
Weight: 0.0013 lbs.
OUT OF STOCK
Due In: 1/6/2015
$0.79
Buy 10-99 $0.69
Buy 100-up$0.59
Part # 090-296
  • GenderFemale / Jack
  • Mounting TypeChassis / Panel Mount
  • ConductorsMono (TS)
  • BrandParts Express
  • Part Number090-296
  • UPC844632010651
  • Product Category3.5 mm Mini Connectors
    (5 Reviews)
  • Weight0.0013 lbs.
View similar products to the 3.5mm Mono Chassis Jack
in the 3.5 mm Mini Connectors product category.
3.5mm Mono Chassis Jack is rated 2.4 out of 5 by 5.
Rated 5 out of 5 by from Solid little jackI bought these for both audio and low power and it has worked well in both applications. A good jack at a reasonable price.
Date published: 2014-01-23
Rated 2 out of 5 by from FrustratedAfter I drilled a hole and placed the jack, I could not get the little ring to catch on the jack. I ended up having to glue it into my project box. The outside ring did not fit the mono jack.
Date published: 2013-02-06
Rated 2 out of 5 by from UnusableThe nut threads are too thin and loose and the solder tabs break off. Where's my refund?
Date published: 2009-05-19
Rated 2 out of 5 by from Fair performanceIt's a cheap jack - the nut cracked and I had to glue the jack in place. But it's affordable.
Date published: 2008-12-17
Rated 1 out of 5 by from Not a Good FitAlthough seemingly well made, the tolerance makes it a tight fit for 3.5mm jacks, and difficult to pull out. Not recommended.
Date published: 2008-01-07
if i wanted to connect my speakers directly to my ipod could i connect this to the speakers with speaker wire and plug my aux jack into this and play music?
Asked by: verwest
What size hole should I drill for the threads to fit?
Asked by: WiseNick
The outer diameter of the socket (threads) is 5.75mm.
Date published: 2013-04-12
what is the current max you can put thru this Item?
I plan on using It as a power input jack along w/the 3.5mm plug, but I,m not sure if it can handle 3-5 amps!
Asked by: steved
I would just use the standard barrel style connector for your power jack rather than the 3.5mm audio jack if there isn't a specific reason why you need the audio jack. I suspect it could handle the 3-5A load considering it is mostly metal, but 3.5mm jacks are designed for less than 100mA--so just be wary.
Answered by: Honest Rob
Date published: 2012-05-17
Do you sell the wrench needed to secure the knurled nut on this item?
Some nuts on 3.5 mm jacks have two dimples to tighten them. I would also like to purchase the tool made for this nut also.
Asked by: Barrysd55
No, we do not sell such a tool, unfortunately.
Answered by: RussR
Date published: 2012-02-20
Customer projects that include: 3.5mm Mono Chassis Jack
