299-286_ALT_0
299-286_ALT_1
3" x 5" Ribbed Paper Cone Shielded Woofer Speaker
Brand:|Part # 299-286
With its unique form factor, this very efficient full range 3" x 5" woofer will perform well in custom or replacement computer workstation speakers, small surround sound setups, and line arrays.
Part # 299-286
  • High efficiency—requires less input for more output
  • Ribbed paper cone with inverted half-roll treated cloth surround
  • Durable stamped steel frame
  • Straight sides reduce footprint and improve baffle spacing
  • Shielded ceramic ferrite magnet
  • Half-sphere dust cap improves high frequency dispersion
With its unique form factor, this very efficient full range 3" x 5" woofer will perform well in custom or replacement computer workstation speakers, small surround sound setups, and line arrays. The shielded magnet structure prevents interference when the speaker is located adjacent to magnetically sensitive equipment.
A low-mass ribbed paper cone with cloth half roll surround contributes to the speaker's smooth, extended response, and the directly-coupled "button" dust cap maximizes high frequency extension. Buyout, limited quantities.
Specifications: • Power handling: 20 watts RMS/40 watts peak • VCdia: 5/8" • Le: 0.50 mH • Impedance: 8 ohms • Re: 7.49 ohms • Frequency range: 150-10,000 Hz • Fs: 150.7 Hz • SPL: 89.6 dB 1W/1m • Vas: 0.081 cu. ft. • Qms: 4.63 • Qes: 1.33 • Qts: 1.03 • Xmax: 2 mm • Dimensions: Outside diameter: 3" x 5-1/16" oval, Cutout diameter: 2-3/4" x 4-3/4" oval, Depth: 2-1/4".
  • Nominal Diameter3" x 5"
  • Power Handling (RMS)20 Watts
  • Impedance8 ohms
  • Cone MaterialPaper
  • BrandFactory Buyouts
  • Part Number299-286
  • UPC844632092145
  • Product CategoryProducts
    (7 Reviews)
  • Weight0.8 lbs.
View similar products to the 3" x 5" Ribbed Paper Cone Shielded Woofer Speaker
in the Products product category.
