3/8" Heat Shrink with Adhesive 4 ft.
Brand:| Model: 5113536869
Product Video
This unique heat shrink is a 2:1 thin wall tubing that has an integral adhesive lined construction. It is ideal for protecting electronic components, wire splices, or wire bundles. Heat to 250°F (121°C) for a skin tight fit. Flame retardant, flexible, and provides a waterproof barrier.
080-113
Weight: 0.066 lbs.
IN STOCK
$5.73
Buy 4-19 $5.31
Buy 20-up$4.82
Part # 080-113
This unique heat shrink is a 2:1 thin wall tubing that has an integral adhesive lined construction. It is ideal for protecting electronic components, wire splices, or wire bundles. Heat to 250°F (121°C) for a skin tight fit. When cool, tube is flame retardant, flexible, and provides a waterproof barrier. Black in color. Sold in 4 ft. lengths.
  • Nominal Preshrink I.D.3/8" (9 mm)
  • Shrink Ratio2-to-1 (2:1)
  • ColorBlack
  • Length4 ft.
  • Adhesive SealantYes
  • Brand3M
  • Model5113536869
  • Part Number080-113
  • UPC051135368695
  • Product CategoryHeat Shrinkable Tubing
    (2 Reviews)
  • Weight0.066 lbs.
View similar products to the 3/8" Heat Shrink with Adhesive 4 ft.
in the Heat Shrinkable Tubing product category.
3/8" Heat Shrink with Adhesive 4 ft. is rated 4.0 out of 5 by 2.
Rated 4 out of 5 by from Good heat shrink, but not much adhesiveWhat can I say? It's heat shrink. The outer wall appears to be of reasonable thickness and quality. However, the heat shrink did not have the same amount of adhesive lining as what I've seen in other brands (with some brands the adhesive oozes out the edges when the heat shrink is heated.... not so with this stuff).
Date published: 2010-01-22
Rated 4 out of 5 by from Works as intendedI bought this to cover the ends of some cables and add the finishing touches to some connectors. The glue is much stronger than others I've used and they shrink very well. I use a small propane hot air blower to shrink the tubing and it works great, I tried the back of the soldering iron and it doesn't work well for me (it may for others, but I prefer hot air). One thing to look for is that when you are done heating the tube you will see the shiny glue at the edges, if it's even, you've heated evenly all the way around.
Date published: 2008-02-04
Videos
Customer projects that include: 3/8" Heat Shrink with Adhesive 4 ft.
