3-1/2" Shielded Paper Cone Midbass/Midrange Speaker 12 ohm
Brand:|Part # 299-971
Build your own line array, repair your classic speakers, or build your own surround sound satellite system with this 12 ohm, 3" paper cone midrange. Save over 50% off the retail price through this Parts Express exclusive buyout. Quantities are extremely limited!
Part # 299-971
  • Paper cone with foam surround for a relatively flat frequency response
  • Shielded motor for close placement to sensitive electronics
  • 12 ohm impedance for parallel-wired MTM speaker configurations
Frequently Bought Together
Looking for that perfect speaker to make a low-cost line array? Look no further! This shielded 3" paper cone midrange plays from 150 Hz all the way up to 15,000 Hz, and is built with a truncated frame for close center-to-center spacing and minimized comb filtering. Additionally, this driver performs equally well as a mini computer speaker and can be used as a satellite surround sound speaker.
A Qts figure of 0.84 also makes this 3" paper cone midrange a perfect candidate for open back dipole speakers. The 12 ohm nominal impedance also makes it ideal for use in MTM configurations when wired in parallel for a 1W/1m sensitivity of over 90 dB! Shielded for protecting sensitive electronics.
Paper cone midranges were originally used in classic 3-way speakers and were known for their ability to reproduce vocals with warmth. Repair, upgrade, or build your own speakers today and save over 50% off the original retail price through this exclusive Parts Express buyout. Hurry, quantities are limited!
  • Nominal Diameter3-1/2"
  • Power Handling (RMS)10 Watts
  • Power Handling (max)20 Watts
  • Impedance12 ohms
  • Frequency Response150 to 15,000 Hz
  • Sensitivity85 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)95 Hz
  • DC Resistance (Re)9.84 ohms
  • Voice Coil Inductance (Le)0.89 mH
  • Mechanical Q (Qms)2.97
  • Electromagnetic Q (Qes)1.17
  • Total Q (Qts)0.84
  • Compliance Equivalent Volume (Vas)0.1 ft.³
  • Maximum Linear Excursion (Xmax)1.5 mm
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Magnet MaterialFerrite
  • Overall Outside Diameter5" diagonally, edge to edge is 4.125"
  • Baffle Cutout Diameter3.875"
  • Depth2.25"
  • Bolt Circle Diameter4.5"
  • # Mounting Holes4
  • BrandFactory Buyouts
  • Part Number299-971
  • UPC848864006369
  • Product CategoryProducts
  • Weight1.2 lbs.
View similar products to the 3-1/2" Shielded Paper Cone Midbass/Midrange Speaker 12 ohm
in the Products product category.
