2.5mm x 5.5mm x 11.5mm DC Plug with 6 ft. Cord
Brand:|Part # 090-492
2.5 mm x 5.5 mm x 11.5 mm plug with 6 ft. cord. Bare wire ends with one conductor marked with a white stripe.
$1.98
Buy 10-99 $1.89
Buy 100+$1.49
Part # 090-492
  • 22AWG per conductor, and it is rated for up to 5 amps at 12VDC
  • DC Power Connector TypePlug
  • BrandParts Express
  • Part Number090-492
  • UPC038975480251
  • Product CategoryDC Coaxial Power Connectors
    (11 Reviews)
  • Weight0.0726 lbs.
View similar products to the 2.5mm x 5.5mm x 11.5mm DC Plug with 6 ft. Cord
in the DC Coaxial Power Connectors product category.
2.5mm x 5.5mm x 11.5mm DC Plug with 6 ft. Cord is rated 4.0909 out of 5 by 11.
Rated 4 out of 5 by from Good fitNice fit in the sockets, nice length of cord. 22awg and the fact that the strands are really fine made this a little hard to use with certain crimp/screw connectors. But it's a power cable and it works.
Date published: 2014-11-17
Rated 5 out of 5 by from Excellent power connector!Works great for my power supply! I built a power supply for my effect pedals to eliminate the many wall warts in my studio, and this connector is just what I needed!
Date published: 2014-04-27
Rated 5 out of 5 by from Right part, right priceThis is exactly the part I needed. It was less expensive that the company I previously ordered from! Arrived quickly.
Date published: 2013-10-11
Rated 3 out of 5 by from Great price, very thin wire.I thought it was a 18 awg wire thickness, but it turns out to be 22 awg. It will probably burn up for the usage I intended it for. 12 volt heated clothing plug. 8 amp load.
Date published: 2012-01-02
Rated 3 out of 5 by from Saved me from buying entirely new power supplyBought this to repair my very heavy duty Toshiba Pro power supply. Wish I could have gotten a longer plug with cord say about 14mm but this was the longest I could find. The plug does work but does want to fall out as it is to short for my computer.The reason I only give 3 stars is that the wire is very small. No laptop would have such small guage wires. If they would make this with a heavier gauge of wire it would be a winner.
Rated 5 out of 5 by from Great Replacement PlugThis product is perfect when replacing a laptop plug since it is right angled. It also comes with a 6ft cable with it which makes connection easier.
Date published: 2009-12-03
  • 2016-02-13T07:12CST
  • co_hasreviews, tv_0, tr_11
  • loc_en_US, sid_090-492, PRD, sort_mostRecent
Can you get us a custom length of cable with custom connectors? For instance, we are looking for 2.1 x 5.5 male  to 2.5 x 5.5 male on the other end with a 4 foot length. We might also be able to do 2.5 x 5.5 on both ends. Thanks, Stan
Asked by: eyemobil
Unfortunately we cannot get these in any custom form.
Date published: 2016-01-18
doe's the end of the wire have a female end or bare wire.
Asked by: railbuff
The end of this wire has bare ends.
Date published: 2015-02-17
2.5mm x 5.5mm x 11.5mm DC Plug with 6 ft. Cord. What size or gauge wire? Thanks, Rene
Asked by: rniolet
Hi Rene, it is a 22awg wire.
Answered by: walts
Date published: 2014-05-29
can you make this with a heavier gauge wire?
Asked by: Tjavorsky
Unfortunately this is the heaviest gauge we offer, however you can buy the connector and larger gauge wire separately and build your own. We only have straight connectors for this however, nothing angled.
Date published: 2014-02-06
hi
OK for 6A 24V?
Asked by: speaker freack
No
Answered by: Nitnub
Date published: 2013-09-21
Which cable is carries the inside of the plug and which the outside?
I have to make sure I connect positive and negative correctly to the power supply: there are two cords coming out of this plug: one is marked with a white line, the other is solid black.Which one of the two connects with the inside of the plug and which one with the outside?If I cannot figure that out I cannot use the cord! Help please.
Asked by: ftonin
The conductor with the white stripe is the positive which is connected to the center of the plug.
Date published: 2015-04-07
  • 2016-02-13T07:53CST
  • co_hasquestionsanswers, tq_8
  • loc_en_US, sid_090-492, PRD, sort_recentQuestionsFirst
