2.5mm 4C Plug to 3.5mm Stereo Plug Adapter 6"
090-507_ALT_0
This 2.5 mm plug to 3.5 mm plug cable adapter features molded connector shells and nickel plated contacts for supreme durability and signal transfer. The microphone portion of the 2.5 mm plug has not been wired into the design, which keeps noise to a minimum.
  • Great for transferring audio from a cell phone to another device
  • Molded connector shells
  • Nickel plated contacts
090-507
Weight: 0.1 lbs.
IN STOCK
List Price$5.99
You Save50%
$2.98
Buy 10-up$2.48
Part # 090-507
Modern cell phones and electronics are built today to serve many functions, one of these being the ability to play MP3s and other compressed music files. Most cell phone manufacturers use proprietary 2.5 mm four conductor jacks instead of the industry standard 3.5 mm stereo jack for the audio out, requiring a cell phone user to buy a hard to find, expensive adapter. Not any longer. This 2.5 mm plug to 3.5 mm plug cable adapter features molded connector shells and nickel plated contacts for supreme durability and signal transfer. The microphone portion of the 2.5 mm plug has not been wired into the design, which keeps noise to a minimum. The adapter may be used to transfer audio from a cell phone or camcorder to a personal computer or another device. The overall length of 6" reduces the cable strain and discomfort associated with standard hard molded adapters.
  • BrandParts Express
  • Part Number090-507
  • UPC844632070242
  • Product CategoryHeadphone Cables & Accessories
    (3 Reviews)
  • Weight0.1 lbs.
View similar products to the 2.5mm 4C Plug to 3.5mm Stereo Plug Adapter 6"
in the Headphone Cables & Accessories product category.
2.5mm 4C Plug to 3.5mm Stereo Plug Adapter 6" is rated 3.3333 out of 5 by 3.
Rated 5 out of 5 by from Good cableWorks just as advertised - like everything I've gotten from PE.
Date published: 2012-01-07
Rated 4 out of 5 by from Functions as advertisedBeware of the wiring scheme. I had to modify it to work for my application. The tips of each end are not wired to each other. The sleeve conn is wired to sleeve on each conn., the ring is wired to first ring. and the tip of the three part conn. is wired to the 2nd ring of the four part conn. I needed tip, ring, sleeve connections on both ends.
Date published: 2011-10-30
Rated 1 out of 5 by from Wrong ItemThis was the wrong item for my applucation. So I returned it for refund!!
Date published: 2010-01-26
Customer projects that include: 2.5mm 4C Plug to 3.5mm Stereo Plug Adapter 6"
